Well , before to start an appropriate thread on the FX section I've to record this particoular pedal that I've created..the point is this: For a strange reason this pedal is very sensible to the output and input inpendance..if I plug my chain directly in my sound card and then run guitar rig2 it sounds horrible, recording with the integrated mic of my pc sounds horrible too, I've no other ideas..this pedal is vey strange
I could plug my amp lineout into guitar rig but then what I've to add? adding an amp sim makes everything so treebly and noisy..
Thanks for now!
Emanuele.
HOW CAN I RECORD THIS SPECIAL FX?
- Superfuzz
- the older brother
Re: HOW CAN I RECORD THIS SPECIAL FX?
I have a VOX Valvetronix LE and it got a pedal loop where I plug my pedals and then line it into the input and record the audio -piece of cake
- Superfuzz
mmm..I've an old zoom 505..maybe I could try it after THAT pedal!
- chrisjedijane
Try plugging your amp line-out into guitar rig, and only using the cabinet simulator (i.e. disable the amp section of guitar rig). You might get better results this way.
- Superfuzz
well so I finally ended by plugging my amp from the headphone out to the soundcard..I have no line out except for the fx send (bu it sounds really bad) so I had to push the soundcard preamp at max the, boost the signal in guitar rig..anyway hums apart the sounds is what it should be so it's quite ok!
Now I've to upload the mp3 somewhere, but WHERE?
Thanks!
Thanks!
- Orang Goreng
Thanks!
- fenderizer
Some recording cards and/or audio interfaces have an Hi-Z input. If your sound card hasn't, maybe consider impedance conversion via (pre)amplifier?Superfuzz wrote:the point is this: For a strange reason this pedal is very sensible to the output and input inpendance..if I plug my chain directly in my sound card and then run guitar rig2 it sounds horrible, recording with the integrated mic of my pc sounds horrible too, I've no other ideas..this pedal is vey strange
With some electronics knowledge , you may even do it yourself, a lot of (quite cheap) OP-amp circuits have high input impedance.
Greetings - the Fenderizer
they're coming to take me away, hahaaa ...
