Logic Question
Logic Question
How do you cut off all the blank space at the end? When I made of one my test songs it had like 3 minutes of nothing at the end. I know there must be a way to cut it off.
- Pingu
Re: Logic Question
I switched from Ableton to Logic two days ago, so i'm not that knowledgeable yet, but you should just be able to shift-click at the start and end of the song and click render. Whenever i end up with a 5-minute silence at the end that's what i have forgotten
"Anything that doesn't take years of your life and drive you to suicide hardly seems worth doing." - Cormac McCarthy
- lalalandstudios
Re: Logic Question
At the very top of the arrange window there is a timeline - there is a small gray box that indicates where the song starts on the left and another one to the right to indicate where it ends - just move the end point where you like and you're good. There may be other ways of defining this but that is how I've done it.
I'm a reasonable man get off my case...
- noirengineer
Re: Logic Question
it's actually good to have a silence at end of song...
unless your looping of coarse, but it allows the reverb
or fx trail (or amplitude of wave) to fully die out without
it cutting it short. But when doing a bounce.. select an area
you'd like to loop highlight it in the timeline selector up top,
then bounce as you wish.
Re: Logic Question
Yeah, but not 5 minutes of it for a 3 minute song like I got hahahanoirengineer wrote: it's actually good to have a silence at end of song...
- fuzzking
Re: Logic Question
Editing: press Esc, a tool box will appear, click the scissors, make the cut wher you want it to be, press Esc, select the arrow (pointer), click in the region you want to throw away, hit Delete.
Nobody exists on purpose.
