Jazzmaster and Jaguar Bridges
- RBJM
I have a '66 JM and a late 90's MIJ Jaguar that have had bridge issues with both lowering all the way - but only on the treble side. Just curious if anyone has ever had s bridge lower by itself? Just curious what would cause it? HVAC vibration from attic unit, stripped screws (which appear to be fine), string tension, ghosts? Many thanks!
- Jonesie
Re: Jazzmaster and Jaguar Bridges
This is very very very common. Use a little blue loctite in the threads and you'll be good to go.
Yep, blue loctite, set to desired height and leave overnight. Job done
- RBJM
Thanks for the sanity check. May just put Mastery bridges on those.
Which may also require Loctite.
- Veitchy
