Aluminum Shield Filing
- armensguitars
Hi all, have very much appreciated the insights from this forum already. Wondering if anyone has any insight into how to best file down an aluminum shield on a Jazzmaster to fit the shrunken pickguard and body and not cause warping. Would using a dremel on the edges and punching new screw holes be enough?
Re: Aluminum Shield Filing
Dremel would work, honestly I might just try sandpaper if it's not more than a little bit.
- armensguitars
I have the impression so far that it will be quite a bit of the aluminum, as it would have to also be along the whole edge if I don't want it to poke out from underneath the guard.
- GreenKnee
Is it fitted to the guitar currently? If so, I would use a really sharp, soft pencil to trace around the guard on to the aluminium as close to the guard as possible to give yourself a line where the aluminium needs removing.
Remove the guard and screw it down to a piece of scrap wood as quickly as you can to prevent shrinkage once it's off the guitar.
Then with tin snips cut off the part of the aluminium guard that protrudes.
Or, buy a repro aluminium shield and do the above steps. Keep the original in a safe place so you can put it back to original if you ever feel the need.
- ThePearDream
You should be able to get a Bastard file from your local hardware store for ~$15. Look for a half-round version, with a flat side and a rounded side, to give you the most versatility. It should only take a few minutes to shave off the edges with that.
Doug
@dpcannafax
@dpcannafax
- armensguitars
The guard is on the guitar, the shield is not, due to the guard not fitting while the shield is on. I guess using a repro shield may be a good idea to avoid permanently messing up the original. However, I am of the opinion that these things have value only in their function so ideally would like to make the shield work with what I've got. Tracing idea is good, and I could likely align the two using the bridge posts then trace all the holes and edges from there. Thank you!GreenKnee wrote: ↑Tue Feb 13, 2024 12:28 amIs it fitted to the guitar currently? If so, I would use a really sharp, soft pencil to trace around the guard on to the aluminium as close to the guard as possible to give yourself a line where the aluminium needs removing.
- armensguitars
I have some, I guess I was wondering more if the dremel could get me smoother edges or if its better to do it by hand. Thank you!ThePearDream wrote: ↑Tue Feb 13, 2024 5:02 amYou should be able to get a Bastard file from your local hardware store for ~$15. Look for a half-round version, with a flat side and a rounded side, to give you the most versatility. It should only take a few minutes to shave off the edges with that.
