Cannot move up the pickup - 64 jazzmaster
Guitarman555
Post by Guitarman555 » Wed Jul 03, 2024 6:33 am
Hey, cannot move the bridge pickup(at the lower spot by bridge)...I don't wanna use raugh power ..any idea?
I have already sanded shrinked pickguard all around the bridge pickup where necessary, but there is one spot where I just cannot shift pick-up up at all. It is the bridge pickup the spot direction to bridge and pots(if you gold the guitar playing it is right and down spot of the bridge pickup). Other three spots move freely. It is definitely not because of pickguard now. Cannot move a single milimetre. The pickups are original with original black rubber. It was refinished and some solder joints remade a long time ago.
Maybe pickup is sticked to the rubber below? Many thanks!
GilmourD
Re: Cannot move up the pickup - 64 jazzmaster
Post by GilmourD » Wed Jul 03, 2024 9:52 am
Are you saying that the screws keep advancing upward but the pickup does not follow? If you pull up on the cover does the pickup move up? Maybe the foam underneath is too squished or too short and isn't pushing up on the pickup to lift it.
R_T_Hermit
Post by R_T_Hermit » Wed Jul 03, 2024 6:35 pm
I was going to suggest looking into the foam (which I call weather stripping.) My 63 Jag had the neck pickup set so low that it sounded muffled. When I tried to move it with the screws it stayed where it was. I found, when I took it apart, that the foam had been so badly compressed, for such a long time that it was hard as a rock and thin. Replaced it with weather stripping and it adjusts fine now. That’s the first thing I would look at.
Isn’t Sunburst a guarantee it’s NOT a refin?
Guitarman555
Post by Guitarman555 » Thu Jul 04, 2024 1:34 am
I cannot move it up even by hands. Pickup is just stuck at its bottom right corner (wheb looking from the players view). When I take it by hands all three other corners of pickup move up successfully. But it is stuck at one corner so i cannot lift it in proper position
DrippyReverbTremolo
Post by DrippyReverbTremolo » Thu Jul 04, 2024 2:50 am
First get it level, then raise all 4 corners in small increments.
One corner is now wedged and stuck.
Highnumbers
Post by Highnumbers » Thu Jul 04, 2024 4:08 am
If it’s not the pickguard, then it’s the foam under the pickup. Change this out and it’ll be adjustable, 100%
Guitarman555
Post by Guitarman555 » Thu Jul 04, 2024 5:53 am
You mean that pickup has sticked to the foam through the long time, right? How to separate pu cover from the foam? Just to pull by force or carefully with an razor blade? Any thoughts?
Post by Pacafeliz » Thu Jul 04, 2024 6:27 am
Any way you like. It usually comes/crumbles off easily.
I've been putting any sort of semi solid rubber foam under the pickups. Works!
GilmourD
Post by GilmourD » Thu Jul 04, 2024 11:12 am
I've been 3D printing it with TPU. Can be made to different dimensions and with different infill percentages for varying stiffness levels. I really wish the car accident in February didn't leave me utterly exhausted all the time because I'd be churning stuff like this out and selling it.
Highnumbers
Post by Highnumbers » Fri Jul 05, 2024 10:00 am
The foam degrades, becomes squished down and no longer pushes the pickup toward the strings.
Just pry it off with a blade or any sort of edge, then replace it with a new one.
Post by 46346 » Mon Jul 22, 2024 12:10 am
[/quote]
[/quote]
yes - the foam should be fresh and bouncy enough to lift up the pickup when you loosen the screws.
if the pickguard has a good opening, the foam should push the pickup up higher easily.
Cat Museum, ACME, Malcolm Mooney, Magic Gas, Dream Apes, The Cooling Time, Kind Hearts and Coronets, Quarks
Guitarman555
Post by Guitarman555 » Fri Oct 25, 2024 11:52 am
Finally done, it was just screw that was touching the cover! I also put a foam under the pickup(no glue needed), because it would fall down back. Many thanks to you as all for great help!
