Glad to hear that. Unfortunately mine had some serious wear where the strap is touching the guitar when I bought it and I want to figure out wich strap I can use so it does not get worse.CastrosfriendChe wrote:Strap has left zero marks on paint.
Please let us know what kind of strap you used!O Drones wrote:I have those marks on mine, same spot. It's the guitar strap that's caused it.
Here is a great article explaining the Jaguar / Jazzmaster tremolo: http://www.webrocker.de/jaguar/2007/05/ ... lo-system/CastrosfriendChe wrote:Is the lock on when the button is closer to the bridge? That's it's usual position, though again, pushed it back and sound wise, ability wise...the whammy bar acted the same.
As you can see there the position closer to the bridge is unlocked.
If you push the switch to the right locked position you should notice a resistance at some point when pulling the tremolo arm. If set correctly you should not be able to push the arm whit the lock engaged.
The right switch is the series bright switch which affects the sound only when you switch the 4-way-switch all the way to the left (4th position = pickups in series).CastrosfriendChe wrote: The other switch, upper to the right. Which position is 'on'? And in the on position is it cutting out some high frequencies or boosting them?
In that 4th position the switch is engaged when pulled to the left and is a bright switch.
You can see that on the switch and control function page in the service manual: http://www.databasesonline.com/guitar/J ... Manual.pdf
