Fender Alternate Reality Electric XII 12-String
- s_mcsleazy
Re: Fender Alternate Reality Electric XII 12-String
hey guys. quick question for anyone who's taken one of these apart. how hot are the pickups? i'm building a xii and the pickups on these felt a bit...... lackluster so if anyone can get me the impedance of the pickups so i can maybe work out something hotter, that's cool
- bessieboporbach
I'm probably telling you something you already know, but it's hard to go by DC resistance readings alone as a measure of the output of these pickups because they have a unique design.s_mcsleazy wrote: ↑Sun Jan 10, 2021 1:06 pmhey guys. quick question for anyone who's taken one of these apart. how hot are the pickups? i'm building a xii and the pickups on these felt a bit...... lackluster so if anyone can get me the impedance of the pickups so i can maybe work out something hotter, that's cool
You can only really use resistance as a way of comparing two pickups of identical design because, in that situation, the DCR will theoretically give you an indication of how many winds around the bobbin there are. So, for example, Seymour Duncan gives DCR ratings for all of their normal humbuckers because they are all constructed identically, the only difference being the number of windings.
So, in short, DCR is pretty much meaningless in comparing XII pickups to pups of any other design.
In terms of output, my sense is actually that the ARXII pickups -- or at least the bridge -- are relatively hot as these things go. Many modern Fender bridge pups put out a lot of output and I don't think the ARXII is an exception.
- s_mcsleazy
yeah i know. i just need a kinda ballpark estimate.bessieboporbach wrote: ↑Sun Jan 10, 2021 4:40 pmI'm probably telling you something you already know, but it's hard to go by DC resistance readings alone as a measure of the output of these pickups because they have a unique design.s_mcsleazy wrote: ↑Sun Jan 10, 2021 1:06 pmhey guys. quick question for anyone who's taken one of these apart. how hot are the pickups? i'm building a xii and the pickups on these felt a bit...... lackluster so if anyone can get me the impedance of the pickups so i can maybe work out something hotter, that's cool
- bessieboporbach
Well what I was getting at is that a ballpark estimate of DCR isn't going to tell you anything about the pickup's output, unless you plan to make one with an identical design, just more windings.s_mcsleazy wrote: ↑Sun Jan 10, 2021 5:04 pmyeah i know. i just need a kinda ballpark estimate.bessieboporbach wrote: ↑Sun Jan 10, 2021 4:40 pmI'm probably telling you something you already know, but it's hard to go by DC resistance readings alone as a measure of the output of these pickups because they have a unique design.s_mcsleazy wrote: ↑Sun Jan 10, 2021 1:06 pmhey guys. quick question for anyone who's taken one of these apart. how hot are the pickups? i'm building a xii and the pickups on these felt a bit...... lackluster so if anyone can get me the impedance of the pickups so i can maybe work out something hotter, that's cool
For example, the bridge pickup of a VM or CV JM has a DCR of like 15k ohms, but that doesn't mean its output is higher than a Strat pickup measuring 8k. It only tells you that it's hotter than the otherwise identical neck pickup measuring 8k.
- s_mcsleazy
ok, i know all this. i know the design of the pickup and the magnets make a difference. i get it. my point is i could get a good baseline from a normal pickup and go from there. in my experience split pickups with the same magnets are usually louder than say a telecaster pickup of the same DCR. i'm going to use that information of what the DCR is on the pickup and apply that to my former knowledge so i can work out what DCR on something else i'd need so i'm not using a pickup that's super hot or super cold for my rig.bessieboporbach wrote: ↑Sun Jan 10, 2021 7:43 pm
- jakeisjake
Got the GAS for one of these...
I also have just about enough cash...I'll be looking soon (altho, I might hold off if Fender is considering another run of them)!
- Nudger
hey mcsleazy
I dismantled a AR XII and found that the pots were 250k.. Not 1M as on a 60s original.
The pickup measured about 10.5k which is in the same ballpark as a 60s XII.
I found my original 66 Electric XII to harsh for my ear and sold it.. I built a XII with 500k pots and it sounded better " To my ear" even with one of the pickups out of a AR XII.
I deduced from this that the pots have a lot more to do with the XII sound than I thought.
So if youve heard a Alternate Reality XII but felt it was a bit tame, maybe try sticking with 10ks pups but experimenting with with diff values pots.
- Soniqfreq
The master built XII uses 250k pots with a 10% taper split and Novak pickups.
- Nudger
By master build are you on about the fender custom shops?
If so that explains a lot..
My original 66 sounded nothing like the carlos lopez builds..
My home builds sound closer to Carlos with lower K pots.
- jakeisjake
Just pulled the trigger on a white AR XII...pretty excited!
- Nudger
Enjoy..dont think youl be disappointed.
Comfy as a 6 to play.
- SignoftheDragon
Congrats- You're going to love it!
