NEW Fender Swingers from Fender Japan!!!
- MKR
Re: NEW Fender Swingers from Fender Japan!!!
looks awesome. By the way, is that a decal they include for you to put on the headstock (if you so choose)?
- Danley
Original Swingers sometimes had the same weird sticker going on, and sometimes did not (or it peeled off.) it’s actually thoughtful they recreated this.
- postchrist
i can’t help but look at fender guitars like they’re legos... bits and pieces to be deconstructed and rearranged. i’d buy one of the one pickup loaded bodies in a heartbeat.
lying dog-faced pony soldier.
- caliban
I think that's also the way Leo looked at his creations.postchrist wrote: ↑Wed Nov 27, 2019 12:06 pmi can’t help but look at fender guitars like they’re legos... bits and pieces to be deconstructed and rearranged. i’d buy one of the one pickup loaded bodies in a heartbeat.
- volhoo
so bitchen
- tammyw
Happy Swinger
This one got a pink pearloid pickguard with a single Seymour Duncan active single coil pickup.
- LizardKing
- Steadyriot.
I really like these, but this is a MAJOR pet peeve of mine; WHY DONT THEY SOLDER THE GROUND TO THE JACK?!?! I know it's not needed but once things gets a little wobbly because jacks loosen; they always do; your signal will start cutting out. And you know that'll happen in the middle of a show or recording session or something else important where you can't have such things happen. It's just a stupid oversight / cost cutting measure that makes no sense.FIREBOT wrote: ↑Tue Nov 26, 2019 2:18 pmOk... put some 10’s on it, and changed the neck plate to an “F” plate. I partially removed the pickguard to get the plastic film off. While it was partially apart, I took a look inside... not too shabby. Full size CTS pots, Switchcraft jack, fully shielded, and some sort of vintage reissue-type pickups with cloth wrapped wires and fiber bobbins. Fender Japan has really upped their game. Sounds great through my Deluxe Reverb... pretty quiet for a single coil vintage-style guitar. I’m pleased...
- Wil_66
I don't know for certain that these are what's on the Swinger, but it looks like it could be. It's called the Kaminari K-brg1
https://www.ebay.com/p/1173656641
- robroe
85 dollars??? Jesus christ.
I'll keep buying 25 dollar toronado and drilling 3 extra holes for free
- HNB
The jack is connected to the plate which should connect the pots and shielding to ground. You can add a ground wire, but it shouldn't be necessary unless the jack isn't making good contact with the metal plate. Old Jags and Mustangs sometimes didn't have a ground wire to the jack either because they are mounted on a metal plate.
Christopher
Lilith Guitars
Lilith Guitars
- Steadyriot.
I know but it's bad practice. We all have had jack's loosen over time. Shit like that happens at the worst of times; so your guitar will start cutting out in the middle of a set or recording session. And why? Because Fender decided it's worth saving 2 cents in parts and labor. It's a shitty practice and it should stop. Just solder a single fucking wire from the jack to the back of the pots. Done.HNB wrote: ↑Sat Mar 21, 2020 2:22 pmThe jack is connected to the plate which should connect the pots and shielding to ground. You can add a ground wire, but it shouldn't be necessary unless the jack isn't making good contact with the metal plate. Old Jags and Mustangs sometimes didn't have a ground wire to the jack either because they are mounted on a metal plate.
- tammyw
You should always check to make sure the jack is tight before playing a guitar, just like you should always check that the lug nuts are tight before driving a car.
Anyway, here's a Swinger with a purple mirror acrylic pickguard and a single JB Jr in the bridge position.
- globalnova
looks great.. did you need to adjust the truss rod with the 10s or was it good to go? tksFIREBOT wrote: ↑Tue Nov 26, 2019 2:18 pmOk... put some 10’s on it, and changed the neck plate to an “F” plate. I partially removed the pickguard to get the plastic film off. While it was partially apart, I took a look inside... not too shabby. Full size CTS pots, Switchcraft jack, fully shielded, and some sort of vintage reissue-type pickups with cloth wrapped wires and fiber bobbins. Fender Japan has really upped their game. Sounds great through my Deluxe Reverb... pretty quiet for a single coil vintage-style guitar. I’m pleased...
- BoringPostcards
I really want to try one of these, but I am guessing I'll never come across one on this middle of nowhere island of mine.
