NGD: CME Player Jazzmaster Sunburst
sciuri
Post by sciuri » Fri Oct 09, 2020 12:14 pm
CME Player Jazzmaster in sunburst with black headstock! I preordered it in May, and it kept getting delayed until finally shipping in mid/late September. The preorder took so long that I had to buy other guitars while waiting for it lol. CME did throw in a t-shirt and gig bag though.
If you are a vintage purist, look away now... Specs here https://reverb.com/item/32722064-fender ... -pre-order.
Initial impressions and pics below! There are other threads about modding this model, so in case it helps someone I included pics of the routing and wiring. I can post more close-ups of the wiring if that would help anyone.
    Look: I'm very happy with the wood grain on the body, and the dark streaks in the pau ferro fretboard look great to me. The finish is almost perfect, with a small segment on the headstock where the black paint didn't create quite as clean of a line as the perfectionist in me would want, but it's only noticeable from certain angles, and the finish is otherwise beautiful. If only it had blocks and binding!
      Feel: The "modern C" satin finish neck is comfortable and smooth for my hands, but it is on the thin side and probably not for those who only like fat necks. If you've played any of the Player series Strats, it's like that, and not far off from my American Standard Tele. I personally enjoy having a variety of neck sizes and shapes, but I've recently been spoiled by a roasted maple neck. I was worried about sharp fret ends like some have reported with the Vintera series and fortunately the frets feel totally fine to me. Some of the frets had mild oxidation already, even after a setup by CME, but that was easy to polish off. Medium jumbo frets are a good balance for me, and for some reason my fingers don't get along with narrow tall frets.
        Sound: I'm no JM pickup expert, but I love the pickups, which are supposed to be pure vintage 65's. They've got a perfect chime that brings out the resonance of the trem system beautifully. I haven't gotten any ice pick sounds out of it but haven't played at band volumes yet. I'm into the 4-way switch that adds both pickups in series for a beefier tone.
          Mods: I'm undecided if I want to swap out the pickguard for a vintage one with rhythm circuit (and then maybe push/pull pots for series and/or phase). For me, the rhythm circuit would be mostly for mojo, or maybe for a quick tone switch or a kill switch, but I think one could approximate the tone closely enough with either the series + tone knob or the neck pickup + tone knob. There is some mild bridge buzz here and there that I'm tinkering with, but I'm considering swapping in an Am Pro JM mustang-style bridge. I'm not sure I feel the need to replace the trem system at this point and still need to learn more.
          Without further ado...
          mbene085
          Re: NGD: CME Player Jazzmaster Sunburst
          Post by mbene085 » Fri Oct 09, 2020 12:47 pm
          The black headstock looks amazing on these.
          I think a gold guard and black plastic would just look *chef's kiss*
          mcbrandt
          Post by mcbrandt » Fri Oct 09, 2020 1:04 pm
          Awesome grain on that fingerboard. I think I actually prefer my pau ferro fingerboard to my previous rosewood one. I did get lucky cause i bought it sight unseen, but i did like 3 coats of linseed oil and that helped darken it a bit.
          HNB
          Post by HNB » Fri Oct 09, 2020 1:04 pm
          I wonder why they didn't shield the cavity walls? That seems odd to me. I thought you painted the bottom and sides?
          @}--Christopher--{@
          DiMarzio Humbucker Fan Club Member
          Mechanical Birds
          Post by Mechanical Birds » Fri Oct 09, 2020 5:02 pm
          Really into the black headstock over burst like that it looks awesome
          monsterdonkey
          Post by monsterdonkey » Fri Oct 09, 2020 5:22 pm
          Are there other JMs without the rhythm circuit that are routed for it? I was surprised to see that here but maybe it’s common.
          blunderbuss
          Post by blunderbuss » Fri Oct 09, 2020 6:19 pm
          I’ve been looking at the Shell Pink one for some time.
          Ryan
          sciuri
          Post by sciuri » Fri Oct 09, 2020 6:52 pm
          Here are two other threads about this series, but I'm not sure how common it is. One theory is that Fender is just repurposing MIM bodies from the Vintera series.
          http://www.offsetguitars.com/forums/vie ... 6&t=112535
          http://www.offsetguitars.com/forums/vie ... p?t=115708
          As others have noted, there aren't any pre-made pickguards that have cutouts for both a rhythm circuit and a 4-way selector switch, so for an "easy" mod one would have to give up the series option. To workaround that, my fantasy mod would be to use a vintage pickguard with rhythm circuit, but then turn the volume knob into a push/pull to keep the series option, and maybe use the tone knob as a push/pull for out of phase. But so far I like the guitar stock. :) I'll probably swap out the bridge though...
          I would have totally gone for Shell Pink if the headstock was matching! That might be the holy grail for me.
          Veitchy
          Post by Veitchy » Sat Oct 10, 2020 4:50 pm
          I was surprised at that too. Almost makes me wonder how much it would cost to land one over here.
          mbene085
          Post by mbene085 » Sat Oct 10, 2020 5:09 pm
          CME has been specifically doing this and advertising it as such. They had an ice blue metallic JM run, also with the blade switch, that they advertised as being routed for a rhythm circuit. I think it was separate from this run of sunburst and pink JMs, because those didn't have painted headstocks.
          Veitchy
          Post by Veitchy » Sat Oct 10, 2020 5:24 pm
          I can understand repurposing bodies (if that's what they're doing) , but it's interesting that they advertise them as such. Maybe it's for full disclosure if someone opens one up and is disappointed at the extra routing (just call it chambering), or they're trying to attract customers who can solder.
          jdr1014
          Post by jdr1014 » Sun Oct 11, 2020 4:56 am
          Congrats! Pretty guitar - very nice fingerboard and body wood grain.
          Larsongs
          Post by Larsongs » Sun Oct 11, 2020 6:13 am
          Great looking Guitar.. Not sure about the Purist aspect but you will have fun with it.. Congrats!
          Sauerkraut
          Post by Sauerkraut » Sun Oct 11, 2020 9:21 am
          Absolutely! A gold guard to match the gold decal would look great.
          Shadoweclipse13
          Post by Shadoweclipse13 » Mon Oct 12, 2020 1:29 am
          You and I think alike. That would make it perfect (for me). The black head absolutely makes it though. Best way to finish a burst guitar scheme I think.
