Mine are on 11.
Treble bleed on volume - yea or nay?
- CivoLee
- Powdered Toast Man
- jorri
Re: Treble bleed on volume - yea or nay?
Im in the camp of being told "you must leave it on full at all times" so yes! I think even most guitarists will never go near it except as a mute button. Changed the tone to 500k to make the same kind of "load" impedance wise.
- HarlowTheFish
A pretty neat way around this for folks who don't do much volume control is swapping out the pot for a switch (2 position for on/off or 3 position for full/half/off). A buddy had a 3-way to get him off, clean, and distortion with his amp setup, using a couple of resistors and stuff to fine tune it. Takes a bit more work to set up, but is way less fussy than a pot for people who don't use it much.jorri wrote: ↑Mon Jan 11, 2021 8:56 amIm in the camp of being told "you must leave it on full at all times" so yes! I think even most guitarists will never go near it except as a mute button. Changed the tone to 500k to make the same kind of "load" impedance wise.
That's a really neat idea. I'll admit that I'm in the camp that I don't use the volume control too much, but I'm also not in the camp that never uses it either. I don't use it for swells, as I've got a volume pedal, but I think I'd feel like I was missing something with a switch for on-off. Although... maybe with a 3-way switch, for on (with volume pot), off, and on (without volume pot), that might be interesting...HarlowTheFish wrote: ↑Mon Jan 11, 2021 2:12 pmA pretty neat way around this for folks who don't do much volume control is swapping out the pot for a switch (2 position for on/off or 3 position for full/half/off). A buddy had a 3-way to get him off, clean, and distortion with his amp setup, using a couple of resistors and stuff to fine tune it. Takes a bit more work to set up, but is way less fussy than a pot for people who don't use it much.
- jorri
Speaking of which, i sort od did this to my Jazz bass specifically, because i did have a couple of settings that are blends of pickups.Shadoweclipse13 wrote: ↑Mon Jan 11, 2021 9:09 pmThat's a really neat idea. I'll admit that I'm in the camp that I don't use the volume control too much, but I'm also not in the camp that never uses it either. I don't use it for swells, as I've got a volume pedal, but I think I'd feel like I was missing something with a switch for on-off. Although... maybe with a 3-way switch, for on (with volume pot), off, and on (without volume pot), that might be interesting...HarlowTheFish wrote: ↑Mon Jan 11, 2021 2:12 pmA pretty neat way around this for folks who don't do much volume control is swapping out the pot for a switch (2 position for on/off or 3 position for full/half/off). A buddy had a 3-way to get him off, clean, and distortion with his amp setup, using a couple of resistors and stuff to fine tune it. Takes a bit more work to set up, but is way less fussy than a pot for people who don't use it much.
But blend pots tend to suck so ive got a five-way with a few resistors.
- jorri
Otherwise i kind of get the effect of more or less distortion from a series switch and a middle strat pickup (much weaker) and JM90 (much louder) on my JM. Especially all those combinations.
