Staytrem vs. Mastery or Mastery vs. Staytrem
V_____
Re: Staytrem vs. Mastery or Mastery vs. Staytrem
Post by V_____ » Thu Jun 12, 2014 8:50 am
Oh, just an update. I tried the staytrem out in a half-finished Jazzmaster build with a trem system and it works very nicely there. Still not sure if i will keep it over a mastery. I'll have to wait until I can plug it in. But I think mastery gets the edge in replacing a bridge on a non-trem guitar to get better height adjustments.
www.shoepedals.com
Mickster
Post by Mickster » Mon Jun 16, 2014 12:25 pm
maurice ravel wrote:staytrem would be perfect were it not for one minor flaw - certain strings touching the lip of the bridge as they break down to the trem. you can remedy this by slightly tilting the bridge backwards until they break clear. still an amazing bit of hardware, love the hex adjustable intonation screws
I leave the staytrem pushed fully back towards the back all the time. Seems not to effect the trem operation, and gives a useful 'reference point' to put the bridge in for tuning / intonation. And like you say it ensures the strings clear that rear lip on the bridge 8)
Mickster
Post by Mickster » Tue Jun 17, 2014 10:44 am
maurice ravel wrote:good to know i'm not the only one doing that
have you noticed any negative effects of not having the bridge float in the middle?
None at all. Tuning after using the trem has stayed rock solid. When I had the bridge in the middle tuning would sometimes go a bit flat/sharp after using the trem, but this way I've had no probs at all.
FWIW I use the trem just for subtle vibrato, accents and don't do huge pulls / dives on it. Not sure if this 'half-floating' method would work if you're doing big up bends on the trem, but for my use it's been really solid. I also add a smear of vaseline on teh saddles when doing a string change & think this helps keep everything in tune.
leicaboss
Post by leicaboss » Thu Jun 26, 2014 2:22 pm
Are there any users here who have replaced an actual Mustang's bridge with a Staytrem or Mastery?
mywhitenoise
Post by mywhitenoise » Fri Jun 27, 2014 2:16 pm
leicaboss wrote:Are there any users here who have replaced an actual Mustang's bridge with a Staytrem or Mastery?
I did. Mustang to Staytrem, Mustang bridge had some buzzing on the low E and I wanted the tighter string spacing...unfortunately my Staytrem introduced way more buzz, I'm kind of unhappy with the exorbitant price.
mywhitenoise
Post by mywhitenoise » Fri Jun 27, 2014 5:01 pm
I tried my best to show how the strings are resting on the plate of the bridge.
Mickster
Post by Mickster » Sat Jun 28, 2014 11:42 am
I can't see the right hand side of the bridge cos the images are too large for my browser, but are you saying the buzzing is because the rear of the string is touching the rear lip of the bridge?
alexdm
Post by alexdm » Sun Jun 29, 2014 7:45 am
Can't you tilt the bridge towards the trem more?
DaveC
Post by DaveC » Mon Jun 30, 2014 12:37 am
Is your neck shimmed? If yes, try taking it out and resetting the bridge height.
Cheers
Dave
mywhitenoise
Post by mywhitenoise » Mon Jun 30, 2014 2:44 pm
DaveC wrote:Is your neck shimmed? If yes, try taking it out and resetting the bridge height.
Nope, no shim. I contacted Staytrem and they said the bridge was pretty low, so I raised it by about a millimeter. It still buzzes, but it's been reduced. Maybe I need to take it somewhere else for a set up.
mackerelmint
Post by mackerelmint » Mon Jun 30, 2014 2:49 pm
Maybe so. My staytrem is a lot lower than yours was, no buzzing. The neck is shimmed, though.
Post by Pacafeliz » Thu Jul 03, 2014 2:45 pm
just put the freshly arrived staytrem on "teh crackwhore". don't notice any magic so far. :-/
she did pop the 1st string, though.
might as well replace them all now, cuz they're OLD!!!
up close and personal!
Post by StevenO » Thu Jul 03, 2014 3:18 pm
Honestly, I feel like there is no magic to the Staytrem bridge, and that's IS the magic. It doesn't change the sound of playability of the guitar, just makes a more solid bridge than a regular Jazzmaster/Jaguar or Mustang bridge. Mine also buzzes in the same manner, but I don't really let that bother me. I just tilt the bridge back towards the trem and it stops buzzing.
Post by Pacafeliz » Thu Jul 03, 2014 3:39 pm
nah i'm not complaining, i just thought it'd make the guitar "so much more alive" and so on. tone fer dayz etc. :P
i had an old mustang bridge on it before and i never had probs with it. i'll just put it on another guitar now.
i just realized the fretboard is über-grimey too. will clean it all off and see what happens.
Gav Haus
Post by Gav Haus » Sat Jul 05, 2014 6:15 am
I have a staytrem on my 62 and think it's impressive... That said, curiosity got the better of me and I've just ordered a Mastery. I need to know!! Will sell whichever I like less!
http://wearerichlist.com
