I hope I got that right, otherwise I'll've bought a very pretty paperweight
That's right.Kinosness wrote:I did some homework and it seems vintage/MIJ radius is 7.25", and Pawn Shop is 9.5".
Look for the option as soon as he makes the next batch.I have decided to offer the option of having the narrower size channel as a lot of people have requested that.
SneakyT wrote:This is really frustrating me. I use the VI daily and really wan't a better bridge option but I can't loose that mute. I use the mute a lot. A 1" Bass VI mute would solve my problem but may be the hardest of all parts to source.
I sent them an email before I found this thread and saw it was 1" channel. This is the response I got.So maybe I'll get a nice bridge one day.Hi
I am sorry but these will not work with a standard size mute, this would
need to be removed, I will add this as a note to the Ebay listing.
I might be producing a narrower version at a later date for those who do not
have problems with setting the intonation on their bass within the width of
a standard Jaguar width bridge.
Thank you for your inquiry.
Regards
John
Hell yes. Made my night!Krayuns wrote:Hi Sneaky,
John got back to me this morning, saying that the first batch of 10 bridges was sold out, and this:
The staytrem Bass VI bridge has a 1" wide channel, which is bigger than the stock and Mastery I believe. Solves intonation issues.zenofbass wrote:Does anybody know what are the major differences between the Staytrem vs Mastery bridges for the Pawn Shop bass VI?
Can you adjust saddle height on the Mastery M1?
Thanks
That is right though the next run of Staytrem will have the option of a smaller channel. Depending on the strings it could be tough to intonate the Mastery on a Bass VI as it has less range than the original Jag/JM bridge. The Mastery also won't work with an unmodified mute due to the post being bigger. Because of those things and price I've never tried one but I'm sure someone will chime in that has.andrewnelles wrote:The staytrem Bass VI bridge has a 1" wide channel, which is bigger than the stock and Mastery I believe.
SneakyT wrote:That is right though the next run of Staytrem will have the option of a smaller channel. Depending on the strings it could be tough to intonate the Mastery on a Bass VI as it has less range than the original Jag/JM bridge. The Mastery also won't work with an unmodified mute due to the post being bigger. Because of those things and price I've never tried one but I'm sure someone will chime in that has.andrewnelles wrote:The staytrem Bass VI bridge has a 1" wide channel, which is bigger than the stock and Mastery I believe.
zenofbass wrote:Will StayTrem's smaller (upcoming) baseplate potentially negatively impact the ease of intonation ? Was wondering what the benefit of the smaller plate is if you don't use a mute?SneakyT wrote:That is right though the next run of Staytrem will have the option of a smaller channel. Depending on the strings it could be tough to intonate the Mastery on a Bass VI as it has less range than the original Jag/JM bridge. The Mastery also won't work with an unmodified mute due to the post being bigger. Because of those things and price I've never tried one but I'm sure someone will chime in that has.andrewnelles wrote:The staytrem Bass VI bridge has a 1" wide channel, which is bigger than the stock and Mastery I believe.
Without the spring to hinder the saddle adjustment depth a smaller channel should be sufficient to intonate most strings. It really just depends on the string and instrument. Lot’s of things factor into intonation ( tension, gauge, core material, setup etc) for whatever reason. I have had to adjust intonation for every brand of strings I have tried. You would think that heavier gauge would automatically mean longer intonation depth but the original D’addario E string gave me more trouble than any of the heavier gauge E strings I tried. The Circle K b & e are way lower tension than the Labella’s I had and yet they need to be longer to intonate. Who knows? After I modded my original bridge every thing I have thrown at it had room to intonate. With the layout of the staytrem saddles you will have as much if not more room than my modded one. I have noticed a lot of people with flats complaining that it won’t intonate with the smaller bridge so If you plan on those you might try them with the original bridge upside down before you drop money on a new one or just be safe and get the 1" one.zenofbass wrote:Will StayTrem's smaller (upcoming) baseplate potentially negatively impact the ease of intonation ?
If you have no plans of installing the mute (which I can’t live without) or a bridge cover then there is no reason i can think of not to get the 1” bridge.zenofbass wrote: Was wondering what the benefit of the smaller plate is if you don't use a mute?
SneakyT wrote:Without the spring to hinder the saddle adjustment depth a smaller channel should be sufficient to intonate most strings. It really just depends on the string and instrument. Lot’s of things factor into intonation ( tension, gauge, core material, setup etc) for whatever reason. I have had to adjust intonation for every brand of strings I have tried. You would think that heavier gauge would automatically mean longer intonation depth but the original D’addario E string gave me more trouble than any of the heavier gauge E strings I tried. The Circle K b & e are way lower tension than the Labella’s I had and yet they need to be longer to intonate. Who knows? After I modded my original bridge every thing I have thrown at it had room to intonate. With the layout of the staytrem saddles you will have as much if not more room than my modded one. I have noticed a lot of people with flats complaining that it won’t intonate with the smaller bridge so If you plan on those you might try them with the original bridge upside down before you drop money on a new one or just be safe and get the 1" one.zenofbass wrote:Will StayTrem's smaller (upcoming) baseplate potentially negatively impact the ease of intonation ?If you have no plans of installing the mute (which I can’t live without) or a bridge cover then there is no reason i can think of not to get the 1” bridge.zenofbass wrote: Was wondering what the benefit of the smaller plate is if you don't use a mute?
That would be ace!HP Hovercraft wrote:Has he ever mentioned the possibility of making a new larger mute plate?
