You guys know what wires the ultra jazzmster uses? Also, I'm looking for a 4PDT slide switch with the product no. 7716744000 but couldn't find this model on the internet. If you could lead me to a good alternative I appreciate it.
Sent Fender an email a few days ago but it seems like they're busy. Then again, I sent it to consumerrelations@fender.com so correct me if there's an email I should contact.
Sourcing for Wire and Slide Switch
- hetouchedabee
Re: Sourcing for Wire and Slide Switch
Fender would have been my first suggestion too for such an obscure part. 4PDT slide switches like the Ultra's are quite rare beasts. Best guess is that it might be this Switchcraft ...
https://www.mouser.com/ProductDetail/Sw ... wqeg%3D%3D
That switch looks consistent with the look of the Ultra's here ...
http://www.offsetguitars.com/forums/vie ... 6#p1591556
Available from all the big electronics supply houses.
As far as wire is concerned, any decent gauge insulated wire is fine - it's just regular nondescript stuff that Fender uses. You could go with shielded conductors for improved shielding, although the ultra has decent pickguard shielding and shielding paint in the cavities, so possibly redundant if you already have that.
- ChrisDesign
Any wire works fine. The capacitive difference between grudges and types is so negligible that it makes no difference to tone. In a pickup, wire gauge is important. That’s because you use meters of wire. But in your cavity you have centimetres.
Cloth covered vs plastic coated is also irrelevant. Fender used cloth covered wire for their vintage guitars because plastic coated wire was unobtainable and expensive. When it became obtainable and affordable they switched. There is no final difference.
Switches also make no tonal difference. As long as they feel good and connect well, there is zero tone influence. You can buy fender switches. You can buy Gibson switches. You can buy any brand. It doesn’t matter because fender, Gibson, and PRS (etc) buy in third party switches; probably from the same factory. If your switch is feeling good, leave it.
- adamrobertt
Plastic wire is easier to work with, if that helps. Cloth wire is more "vintage correct" and looks nicer, but you're not gonna be staring at the wiring anyway. Guessing the Ultra has plastic wire anyway though.ChrisDesign wrote: ↑Fri Jul 03, 2020 10:25 pmAny wire works fine. The capacitive difference between grudges and types is so negligible that it makes no difference to tone. In a pickup, wire gauge is important. That’s because you use meters of wire. But in your cavity you have centimetres.
- ChrisDesign
100%. The ultra series are modern in every way
- hetouchedabee
Thanks guys, seems like I've found the parts I need. Attempting to build my own version of the ultra jazzmaster
