Hi, I need some help with rewiring my Jaguar HH special MIJ. Maybe someone can point me into the right direction.
The wiring is a standard Jaguar setup with 1Meg pots and .01 resitors. The stock Humbucker were replaced by a P33 (P90 style at neck) and a humbucker at the bridge position.
The problem is: Neck PU sounds quite nice even a bit bass heavy but I would like to keep it as it is. Could be a tad brighter.
The bridge PU sounds terrible. It is a decent humbucker by David Barfuss. Maybe not the hottest one but should sound quite nice. I tried to replace pots with 500k and it did sound better. But I didn't like the sound of the neck PU so I changed it bacl
Any idea what would be the easiest way to improve? Right now I only use the neck PU and don't care much about the 2nd neck circuit. I wouldn't mind a simple Les Paul setup.
Jag HH wiring
- alexpigment
Re: Jag HH wiring
Have you tried raising the bridge pickup and slightly lowering the neck pickup? That's should get them more in the same ballpark so that you have a better chance of EQing your amp/pedals so that they both sound good. Having said that, conventional wisdom is to have a hotter bridge pickup than your neck pickup so that neither is too muddy or thin, but you're asking for the simplest way, and I assume that means not buying new pickups.
Note: changing the pickup heights as described might make you like the 500k pots better, but you can obviously just turn the tone knob down to 7-8 to get a roughly similar effect.
- ChrisDesign
Re: Jag HH wiring
You have two knobs at near the jack, so a standard Les Paul wiring job is impossible; but you know that. I can draw you a wiring diagram of volume pots at the bottom, tone pots at the horn? Or would you like a different setup?
- siam
Re: Jag HH wiring
That would be awesome. Let me think about a setup.
Re: Jag HH wiring
If you wire it with volume pots by the jack and tone pots in the rhythm section, be sure to shield everything well. There will be two of those super-long wire runs (from output plate to rhythm plate) compared to one in a standard jag layout, so it'll be more prone to noise.
- jorri
Re: Jag HH wiring
If you like the bridge with a lower value pot, but neck to remain same, you can add a fixed resistor i think. A 1meg or 500k to ground off the bridge hot wire, or even a trimpot. I think a 500k would reflect changing two 1meg pots to 500k.
Parallel resistor law:
2*1meg=500k. 2*500k=250k. (2*1meg)+500k=250k. (Not actual addition, the equation is 1/r and more confusing than worth it)
But maybe it changes volume taper i am not sure if you mind.
Also i think play with pickup heights. Some guitars like the bridge higher (same distance to string if it were fretted last fret) and others just same distance to open string imho.
- siam
Re: Jag HH wiring
That is a good point to add a resistor. Easy to be done.
I did try different hights of the PU.
- siam
Re: Jag HH wiring
@Chris Design,
did you get my PM? I'm not sure if that went through.
Best
Gerrit
Best
Gerrit
