Johnny marr jag and american pro neck
gildebrand
Post by gildebrand » Fri Jan 08, 2021 11:37 am
Hello folks, so I'm getting a marr jag body set up for a 9.5 neck, decided to go with a American pro fender for jaguar, will the nut be ready for 11-49 string? Or will need to be filed? Thanks guys
HarlowTheFish
Re: Johnny marr jag and american pro neck
Post by HarlowTheFish » Fri Jan 08, 2021 12:30 pm
You might need to widen it a bit, but you can do that yourself by running the strings through the nut slots -- just use the section closer to the tip that's gonna get cut off anyway. If you want to invest in nut files or abrasive cord, that'll work well too.
