Switchcraft Toggle Help
HNB
Post by HNB » Mon Jan 11, 2021 7:08 pm
I got one of these funky toggles that has three outputs instead of the usual two. How do I wire it correctly? I put the neck and bridge in the normal outer two spots and ran the three outputs together but I end up with neckmid/neckmid/bridge. :(
@}--Christopher--{@
DiMarzio Humbucker Fan Club Member
HNB
Re: Switchcraft Toggle Help
Post by HNB » Mon Jan 11, 2021 8:24 pm
It looks like if I disconnect A1 but keep b1 and a2 together it should work as normal.
@}--Christopher--{@
Shadoweclipse13
Post by Shadoweclipse13 » Mon Jan 11, 2021 9:29 pm
Wow, I've never seen those before. I think a continuity check would solve it, but I have a feeling that I'd still be confused :D
timtam
Post by timtam » Tue Jan 12, 2021 12:16 am
That switch is for a 3 humbucker Les Paul.
https://guitarelectronics.com/switchcra ... ul-nickel/
HNB
Post by HNB » Tue Jan 12, 2021 9:25 am
Yeah I was dumb and ordered a three way switchcraft right angle toggle and didn't pay enough attention to the picture. LOL
@}--Christopher--{@
HNB
Post by HNB » Tue Jan 12, 2021 9:36 am
I was right. I disconnected that one and they work as it should. :) I will post a picture in case someone else gets one of these three leg output toggles by accident. :)
@}--Christopher--{@
HNB
Post by HNB » Tue Jan 12, 2021 9:38 am
Here it is. That lower left guy needs to not be attached to have it function as a typical three way switch. :)
Image2021-01-12_09-37-14 by Christopher Louck, on Flickr
@}--Christopher--{@
