New Bridge Pickup won't work by itself
reese_jpg
Post by reese_jpg » Wed Jun 02, 2021 7:07 am
Hey all,
I've got a Squier Classic Vibe 60s Jazzmaster I wanted to mod a bit. I replaced the bridge pickup with a Seymour Duncan JB, and everything's been working perfect. All of a sudden, the bridge pickup is really quiet, to the point my amp at max volume is quieter than what I normally have it at 30% volume.
My original guess was that my first attempt at soldering was bad, but the bridge pickup works at perfect volume when I have it set the the middle position. I tapped every pole piece and got a good loud sound, but as soon as i set it back the the bridge only, it's quiet again.
My only guess now is that the toggle switch could be bad? The neck pickup, in the past, has just cut out if I switch it too fast, so it wouldn't be the first issue with it. I'm pretty new to this, so any suggestions or ideas would be much appreciated
Update: I just used some contact cleaner and it fixed the problem
Lame Pseudonym
Re: New Bridge Pickup won't work by itself
Post by Lame Pseudonym » Fri Jun 11, 2021 6:42 am
You've probably got it. I used to think that a switch is either on or off but sometimes there's some weird halfway.
But check your wiring too.
Sweetfinger
Post by Sweetfinger » Sat Jun 12, 2021 7:32 am
Is the "30%" sound really bright? Does your tone control now also act like a volume?
ChrisDesign
Post by ChrisDesign » Sat Jun 12, 2021 8:51 pm
Get a good replacement switch. Ignore Fender parts and go for Switchcraft. Get one the same shape as you already have because you know it will fit.
Right angle: https://www.allparts.uk.com/products/to ... witchcraft
Standard: https://www.allparts.uk.com/products/to ... witchcraft
