Is my Squier Bullet Mustang compatible with vintage machine heads?
- RominRonin
Pretty much as the title says. I really like the vintage machine heads on my jag Stang and would like to swap the stock items out on the bullet mustang for those. I just want to know if they’re compatible without modification before buying.
If not, what modifications am I looking at having to make for compatibility?
Thanks
Thanks
- Steadyriot.
Re: Is my Squier Bullet Mustang compatible with vintage machine heads?
Depends on what you call compatible. You’ll need conversion bushings and you’ll need to drill holes for the screws in the back of the headstock.
- RominRonin
It would be compatible if I didn’t have to make irreversible changes, like drilling new holes.
I like the vintage style top-threaded string posts more than the modern hole-in-the-post style.
Do you reckon drilling holes is a must then?
- alexpigment
I think you'll have to ultimately drill some holes one way or another, but if you install Fender ClassicGear tuners, those holes should be obscured. Essentially, they install in the same way that all Fender modern tuners do by using two little pin holes under the back of the tuner. The tightening is done via a nut on the front side of the headstock.
The downside is that you need to drill those pinholes, which is its own pain, but they make a jig for it. Link with instructions and jig. . The other downside is that you'll still have the holes from the original tuners showing.
Personally, if you plan on keeping the guitar and prefer vintage tuners, I would just accept that you'll need to drill new holes and go that route. But you'll need conversion bushings for 10mm holes so that the vintage ones fit. Good luck!
- GilmourD
The link in that article to the jig is dead but here's the correct link.alexpigment wrote: ↑Mon Jun 05, 2023 4:34 pmI think you'll have to ultimately drill some holes one way or another, but if you install Fender ClassicGear tuners, those holes should be obscured. Essentially, they install in the same way that all Fender modern tuners do by using two little pin holes under the back of the tuner. The tightening is done via a nut on the front side of the headstock.
https://www.stewmac.com/luthier-tools-a ... drill-jig/
But, also, OMG! $72???
But it also looks identical to this.
https://brownsguitarfactory.com/store/t ... ill-jig-2/
But then you have this.
Tuner Jig Drill Guide 3.0 Stencil for Fender Tuners (3D Printed) https://reverb.com/item/41181924?utm_so ... t=41181924
Or you could 3D print your own.
https://www.thingiverse.com/thing:844734
https://www.thingiverse.com/thing:2331177
Or, if you're gonna spend a bit of change, this one looks quite versatile.
G-Tech Guitar Works Tuner Drilling Jig - Single/Two Pin - Fender Schaller Squier - Locking https://reverb.com/item/38069284?utm_so ... t=38069284
I haven't used or vetted any of these, so I'm not making any actual recommendations, but somebody else here may have.
I have access to a 3D printer, so maybe I'll try one of those myself.
- alexpigment
Honestly, I was really sort of saying-without-saying that the jig option was not worth the time/money/frustration. But I did check out the 3D printed option above, and the multi-hole design takes away a lot of the annoyances with the job (alignment becomes a non-issue). The price is very reasonable too.
- GilmourD
Agreed, especially considering that I prefer regular Kluson-style tuners and they're not that hard to install without a jig. That said, every once in a while you come across a headstock where the tuner holes are spread out just a tiny bit further and Klusons don't fit.alexpigment wrote: ↑Mon Jun 05, 2023 5:22 pmHonestly, I was really sort of saying-without-saying that the jig option was not worth the time/money/frustration. But I did check out the 3D printed option above, and the multi-hole design takes away a lot of the annoyances with the job (alignment becomes a non-issue). The price is very reasonable too.
- RominRonin
Just thought I’d put closure on this thread.
I bought some Gotoh vintage machine heads, I drilled the holes (with a dremel and careful measurement), and I haven’t ordered the conversion bushings yet, they’re so expensive on stewmac (especially considering the cost of eu shipping and duties). So for now I have painters’ tape wrapped around the out-of-the-box bushings.
So far im happy with how this turned out. The bushings are the biggest bummer - I wish I could get them for less in the eu.
Since the original post, I bought a sonic mustang with maple fretboard. No difference though as far as headstock is concerned.
- LVC
If you're ok with ordering from China (and waiting for about a month for delivery):RominRonin wrote: ↑Tue Dec 19, 2023 12:31 pmI haven’t ordered the conversion bushings yet, they’re so expensive on stewmac (especially considering the cost of eu shipping and duties).
https://www.eyguitarmusic.com/102mmNick ... _1586.html
https://www.aliexpress.com/item/33028427492.html
Create art, not content
- GilmourD
Where in the EU are you? Can you find AllParts TK-0900-001?RominRonin wrote: ↑Tue Dec 19, 2023 12:31 pmJust thought I’d put closure on this thread.
- Steadyriot.
Thomann has them for 10,-RominRonin wrote: ↑Tue Dec 19, 2023 12:31 pmJust thought I’d put closure on this thread.
- RominRonin
Just yesss!
Thank you fellow offset fans.
- GilmourD
