My 2006 Jaguar Bass is in the shop getting a NOS Badass II bridge I’ve had for 15 years installed and now I’m wanting to have new pickups installed. I go with Lollar a lot (they’re only three miles from me) but I’m very interested in the Fralin Split Jazz set. The stock output is higher than on a vintage style J pickup, closer to a P-bass pickup which isn’t really a problem but I play it in series mode most of the time and that will increase to output even further still. Anyone have any experience with these pickups they’d care to share? I play mostly alt, grunge and surf styles.
I’m currently thinking a 5% underwound set so I have a cleaner, more vintage tone in Parallel mode that will thicken up when set to series may be the way to go and cover more sonic ground.
Thanks!
Any experience with Fralin Split Jazz pickups?
- therizzla
- therizzla
Re: Any experience with Fralin Split Jazz pickups?
I sent Fralin an email and they suggested the 5% underwound set so I guess that's the direction I'm going to go!
reverb.
- eggo_princess
late to the game here. but I used to have the 5/10% overwound set and they were better than most hc jazz pups I've used IMO, second only to the Seymour Duncan apollo.
I found the overwound set lost some highs but I was able to get some back by running 500k pots all around. I still found the bridge pup to be quieter than the the neck, so would recommend you get the bridge at stock or ever 5% overwound relative to your 5% underwind neck pup.
