Wiring help re. rhythm circuit
SixStringSlinger
Post by SixStringSlinger » Sun Aug 04, 2024 6:07 am
Good morning all. I could use some help with some wiring.
I'm wiring a guitar with this diagram:
It's basically a Jazzmaster diagram but with the rhythm circuit applicable to all pickup positions rather than just the neck. I've used it before and I know it works.
I'm also using a 4-way rotary switch allowing for each pickup on its own as well ass series and parallel combinations, and a phase switch on the bridge pickup. All of this works fine so I don't believe the problem lies here. I'm also using a 100k pot for the rhythm circuit's tone control per my preference.
The problem is that, on the rhythm circuit, the volume control, going from 10 to zero, drops volume only about halfway down its travel before coming back up. The tone control also doesn't work properly.
From the searching I've done the most common solution here seems to be a lack of a ground connection from the volume pot lug that the tone cap is connected to, but I have that grounded to the back of the volume pot.
I'm also using Jag-style metal plates, and I have a bit of heat shrink between the rhythm circuit bracket and the plate as there was some wobble there. Not sure if that's relevant.
I've tried this with two different sets of pots and two different rhythm circuit switches, so I don't think that's the issue, either.
Any help you could provide to my sanity would be appreciated. Thank you!
timtam
Re: Wiring help re. rhythm circuit
Post by timtam » Sun Aug 04, 2024 9:31 am
How is the volume pot body itself grounded in your circuit ?
SixStringSlinger
Post by SixStringSlinger » Sun Aug 04, 2024 10:37 am
The cap goes through the lug shown in the diagram, and continues past that onto the body of the pot. The leg is soldered both at the lug and the back of the pot.
alexpigment
Post by alexpigment » Sun Aug 04, 2024 6:19 pm
The issue may be that the grounding of the rhythm circuit volume/tone pots doesn't actually go to ground (i.e. it doesn't ultimately end up at the ground lug of the output jack). It may be best to solder a wire from the back of the rhythm circuit pot to the back of the lead circuit volume pot just to make sure. The heat shrink under the bracket could be related (it effectively insulates the contact from the pot to the plate), but if the rhythm plate itself isn't grounded it doesn't really matter.
On the other hand, if you have a multimeter, you can just check for continuity from your rhythm circuit pots (i.e. the backs of them) to the nut that holds your output jack in place on the other side.
