Help! I changed pickups in my JM about 6 months back. All was fine until recently.
I noticed after one flight, the sound cut out if i tapped the bridge pickup or volume pot.
It's now cutting out all the time..
Contact cleaner on the pot seems to rectify the problem in the short term, but I gotta get to the bottom of it..
Any help would be greatly appreciated
Thanks in advance!!
Help! Sound Cutting Out..
- the rollerdoor
Last edited by the rollerdoor on Sun Jun 22, 2008 8:38 pm, edited 1 time in total.
- the rollerdoor
Re: Help! Sound Cutting Out..
Er.. Anyone?
- Soochdaddy
This might be a long shot, but here is an idea since you mentioned it took a flight...the rollerdoor wrote: I noticed after one flight, the sound cut out if i tapped the bridge pickup or volume pot.
A day or so after I got my JM, my toddler knocked the case over (guitar was in the case). I checked it out... no damage... but plugged it in and no output.
Long story short, the hot side of the input jack had moved enough to make contact with the brass tub and shorted the output to ground. I would take off the pickguard and plug in the input jack to your amp... tap on the pole pieces. If it's alive, then try to adjust the position of the input jack so that when you put the pickguard back on, it does not inadvertently allow the hot side to short your signal when assembled.
Other than that, if it's intermittent as you describe, it's very likely a mechanical issue caused by vibration that is somehow causing your output to short to ground. The three-way swtich is another place where the leads can make contact with the case of the guitar.
Good luck.
"I want to be able to purchase gin in bulk at Costco on a Sunday. So I totally voted." - chrisrnps
"Always socks on cocks-as to protect my low hanging guitar from getting 'cock rash' when playing in the nude, of course." - basique
- the rollerdoor
Thanks! Yeah. It's had a few knocks within it's case now (similar to your situation). I'll look at all you've mentioned.
I remember going to o/size baggage once and loading onto the conveyor belt only to watch the guitar cases drop off
the end to fall onto the ground...
Aluminium flight cases are the only way to go.
Or private charter, A la Iron Maiden
- Soochdaddy
Kids... God bless 'em...
