4 way rotary switch wiring for JM?
ryanthellama
Re: 4 way rotary switch wiring for JM?
Post by ryanthellama » Wed Jan 12, 2022 1:52 pm
Nudger wrote:
Wed Jan 12, 2022 11:16 am
Heres Two of my high tech diagrams of 4way rotary wiring.
No1
N
N/B Series
N/B Parallel
B
No2
N
N/B Parallel
N/B Parallel "out of phase"
B
These diagrams are for use with ALPHA 4 way 3 pole (blue white)
If I put the rhythm circuit going in where you have the Neck+, will that be correct?
gibs
Post by gibs » Thu Jan 13, 2022 11:40 am
That should work, so long as your running the neck pickup to the rhythm circuit switch first, and then the send of lead side of the switch to the rotary, that’s how it works with a toggle switch.
ryanthellama
Post by ryanthellama » Thu Jan 13, 2022 12:05 pm
Okay perfect, that makes sense. Thanks so much!
