Shadoweclipse13's Master Schematic Page!
- Deadbe4r
Re: Shadoweclipse13's Master Schematic Page!
I've been digging through this thread, can't quite find what I'm looking for, so I made my own.
Can anyone verify this wiring works as a master series/parallel rotary switch. Its a 2 position 2 pole rotary switch.
My other question is whether the pickup selector switch will always work, or will engaging series override the whole thing? I'd like the pickup switch to always work and only have series/parallel switching while the 3 way toggle is in the middle position.
As for the numbered position, the numbers I have shown are how it actually is on my switch. 1 and 7 are pairs and 2 and 8 are pairs.
- bodhi
Should be fine, but it's past midnight locally
That rotary is basically identical to a dpdt toggle switch in functionality, so series will always take precedence over the pickup selector. With this wiring you don't have any dead spots as with some variations, though. I don't believe this is possible to achieve with a dpdt switch, and the three-way toggle switch itself might in some variations be enough to not make it possible, you'd need for the middle position lugs to be unconnected without soldering them together. Haven't really thought it through, but it's at least possible to achieve with a three way blade superswitch.
- Deadbe4r
Thanks so much for taking a look! I am actually using a Gibson style toggle switch, so it does have separate lugs for the middle position. I just drew it as if they were pinched together and soldered out that way.bodhi wrote: ↑Sat Jan 30, 2021 2:46 pmShould be fine, but it's past midnight locally
So, it may be technically possible to achieve my original goal. I'll take another crack at it with this new info in my mind, unless you're able to draw up something faster.
Thanks again.
Just a tip for people staring hard at their wiring diagram and wondering if it will do exactly what they want, with no unwanted side effects ....
If your switching has say 4 positions, print out 4 copies of your wiring diagram. On each copy, use a highlight pen to draw over/highlight the wiring that is "in circuit" for one position of the switch. That should show you if you have any missing or unintended connections.
Drawing a schematic (circuit diagram) from your wiring diagram can also make the way the circuit will actually work easier to see. Designers actually usually start new designs with a schematic. Once you know it will work, you draw the wiring diagram from the schematic.
This. I've done things like this a few times to help figure out a schematic. It really helps!timtam wrote: ↑Sat Jan 30, 2021 6:42 pmJust a tip for people staring hard at their wiring diagram and wondering if it will do exactly what they want, with no unwanted side effects ....
- bodhi
Actually went through this on paper yesterday evening, and the type of three-way switch doesn't really matter. I can't think of a way to do a non-overriding series position no matter if you're using a dpdt or 3pdt toggle...
- Deadbe4r
Yeah, I've come to the same conclusion. Fun thought though. Thank you for the help.
- Flurko
I'm trying to draw a new circuit for my neck single / bridge humbucker jazzmaster and I'm hitting a wall, is what I want to do even possible ?
I'd like to use the rhythm switch like this :
-a DOWN position with the normal volume and tone, and the 3 way going to neck pickup/neck pickup + split HB/split HB
-an UP position with the rythm side volume and tone rollers, and only the bridge pickup in full humbucker.
Is that even possible ? I know you only need one half of the DPDT switch to split a humbucker, but I'm not really sure if you can also use the rest of the poles to have what are mostly two separate circuits.
Thanks !
Thanks !
- Jaga
I'd say that it is not possible with DPDT. There are, however, 3PDT and even 4PDT switches made by switchcraft, but I'm not sure if they will fit with existing DPDT switches.
Check out my videos: https://www.youtube.com/user/alexeyjaga
The Ultra jazzmaster uses the 4PDT Switchcraft 50212LX ...
https://www.mouser.com/ProductDetail/Sw ... wqeg%3D%3D
They will! At least the 3PDT will. They should be the same frame, so the 4PDT should too, but I actually have a 3PDT in hand for my JM upgrade and it definitely does fit. I emailed Switchcraft a month or two back on information. The part number is 50209lx (3PDT). The only difference is that the mounting holes aren't threaded like the standard switches. So, you'll need a nut with the screw as well.
- Flurko
That's great, thanks for the info ! Now to decide if I wnat to order this specific switch or if I should stop ordering random guitar parts and figure out a logical and usable way to get the sounds i want with these pickups (neck, neck + split bridge, full bridge) with the parts I have (standard jazzmaster layout), without having to flip 3 switches to get from one usable sound to another..
What I would do there I think is 2 switches.m, instead of a 3-way toggle: 1 for humbucker split, 1 for 3-way duties.Flurko wrote: ↑Tue Feb 02, 2021 4:49 amThat's great, thanks for the info ! Now to decide if I wnat to order this specific switch or if I should stop ordering random guitar parts and figure out a logical and usable way to get the sounds i want with these pickups (neck, neck + split bridge, full bridge) with the parts I have (standard jazzmaster layout), without having to flip 3 switches to get from one usable sound to another..
- bodhi
I'm a fan of trying sounds out in a playing situation, so you could at least wire up a test rig with separate switches with what you have at hand. To see if the combos seem to work out, and perhaps if you need to tweak some values or add extra stuff...Shadoweclipse13 wrote: ↑Tue Feb 02, 2021 7:44 amWhat I would do there I think is 2 switches.m, instead of a 3-way toggle: 1 for humbucker split, 1 for 3-way duties.Flurko wrote: ↑Tue Feb 02, 2021 4:49 amThat's great, thanks for the info ! Now to decide if I wnat to order this specific switch or if I should stop ordering random guitar parts and figure out a logical and usable way to get the sounds i want with these pickups (neck, neck + split bridge, full bridge) with the parts I have (standard jazzmaster layout), without having to flip 3 switches to get from one usable sound to another..
- tsturm
shaoweclipse13's wiring diargram of the dp3t switch above that starts with "Requested by Morrigaen" won't work, the ground wire for the pickup isn't grounded when in the top dark circuit position. Hopefully people aren't using it.
But, I found a solution. A Bass Cut will work on the OOP switch (because it doesn't require a ground). Here is my solution (i know the wire to the output jack doesn't need to go from the dp3t switch, but it also doesn't matter, thx ICBM for pointing this out & I forgot to ground point 1 on the tone push pull pot, be sure to do this or the coil won't split):
