installing srap locks?
mavsbball
Post by mavsbball » Fri Mar 07, 2008 5:21 pm
hi what kind of strap locks do you all recomend for a JM and how difficult is it to install them? is there any wood work to be done or do they fit in place of the original strap button?
andtrea
Re: installing srap locks?
Post by andtrea » Sat Mar 08, 2008 12:40 am
I have Schaller's Strap Lock in all my guitars (JM, Strat and SG).
Easy to install and reliable; here's an italian website with some informations about strap-locks.
Gordon
Post by Gordon » Sat Mar 08, 2008 5:24 am
If it doesn't fir correctly: you take a match, that you file with sandpaper a bit, to get rid of the edges. You put it in the screw hole to measure the length, and cut what you don't need. A drop of glue on one end, and you put it in the hole. With a pin, you make a tiny hole in the middle of the match end, which will serve as a pilot hole for the screw.
Stratelejazzuar
Post by Stratelejazzuar » Sat Mar 08, 2008 4:14 pm
Gordon wrote: If it doesn't fir correctly: you take a match, that you file with sandpaper a bit, to get rid of the edges. You put it in the screw hole to measure the length, and cut what you don't need. A drop of glue on one end, and you put it in the hole. With a pin, you make a tiny hole in the middle of the match end, which will serve as a pilot hole for the screw.
i usually use toothpicks, instead of matches  ;)
Post by StevenO » Sat Mar 08, 2008 4:57 pm
Whenever I've installed strap locks, I always used the same screws that guitar originally came with. If I don't ever plan on switching the screws back to the original, I put some wood glue in the hole and then install the strap button.
With my jazzmaster, instead of installing strap locks, I just removed the strap buttons and put a washer in between the button and the strap so that the strap won't come off. Works fine and costs literally nothing since I found the washers on the ground outside, :)
Gordon
Post by Gordon » Sun Mar 09, 2008 12:30 am
Stratelejazzuar wrote: i usually use toothpicks, instead of matches  ;)
Better indeed. When one has toothpicks. :P
fullerplast
Post by fullerplast » Sun Mar 09, 2008 5:09 am
Toothpicks were invented in Georgia USA...
Otherwise, they'd be teethpicks.
;D
Q. Are we not men?
Black Cat Bone
Post by Black Cat Bone » Tue Mar 11, 2008 2:35 pm
I ordered Schaller locks recently and got them over the weekend - to be honest I find them a bit ugly as they stick out a long way from the guitar - not my idea of neat really.  I am looking at swapping them for a different brand with a better design - will let you know when I've decided as there are a few to look at!
"It was then that I realised what cool really meant...and seven strings aint even in the equation..."
OffYourFace
Post by OffYourFace » Tue Mar 11, 2008 7:16 pm
fullerplast wrote: Toothpicks were invented in Georgia USA...
;D
;D ;D ;D  :D
Black Cat Bone
Post by Black Cat Bone » Wed Mar 12, 2008 1:12 pm
Here's a pic of the Schaller attached to my Jag project.  in a word "EEeeeeewww".
i can't stand how far it sticks out, how far from the body the strap sits nor the unsightly chunky bit that clamps onto the button.  If I'd have found clear pics like this I'd never have ordered them.  there are other options I'm looking at that are more aesthetically designed and i will post a pic when I settle on a brand.
Black Cat Bone
Post by Black Cat Bone » Wed Mar 12, 2008 1:14 pm
By "clear" i obviously mean "big"...clearly not "clear"...doh!
Ludger
Post by Ludger » Wed Mar 12, 2008 4:20 pm
I have the Jim Dunlop strap locks.
Here they are in the on:
and off position:
ETA: There was some minor drilling involved in putting these on.
afunkymonk
Post by afunkymonk » Thu Mar 13, 2008 3:07 am
I have used both schaller and dunlop strap locks. The Dunlop ones are still on my CS strat, the schallers are in a box somewhere. I prefer vintage strap buttons on a vintage guitar.
Schaller locks look well engineered but have the annoying habit of unscrewing the strap button over time, necessitating the matchstick/toothpick re-dowelling trick on a regular basis.
The Dunlops seem more agricultural, but are actually a better design, and the buttons are larger, meaning even without a strap equipped with locks, you are less likely to lose your axe on that emphatic solo where you drop to your knees with your eyes closed...
If you aren't planning to drop to your knees with your eyes closed etc, you may not actually need strap locks.
Why is Spain? Where are the Snowdons of yesteryear?
Surfoverb
Post by Surfoverb » Thu Mar 13, 2008 4:46 am
Black Cat Bone wrote: Here's a pic of the Schaller attached to my Jag project.  in a word "EEeeeeewww".
I did the same thing: Ordered them, put them on and right away took them off and got rid of them. I hate the way they look and I don't move around enough to warrant them.
Black Cat Bone
Post by Black Cat Bone » Thu Mar 13, 2008 9:59 am
RE: Dunlops - they are certainly looking a better option!  I looked on a website and see they do a version where you imbed the female portion into the body so that would bring the strap flush to the body a'la normal button fixtures.  i'm considering it!
