Coronado Aftermarket Necks?
iodine74
Post by iodine74 » Mon Mar 24, 2008 4:51 pm
Anyone know a place to get an aftermarket Coronado neck?  I'm mainly just interested with that headstock shape.  I've got a picture of a franken-Jazzmaster that was on Ebay a couple years ago and they'd put a coronado neck on this body and the thing just looks sweet.  I'll have to post a shot of it.
The idea to do an offset build is growing and growing and if I can do the coronado style headstock, I might take that approach.
Marc
Re: Coronado Aftermarket Necks?
Post by Marc » Mon Mar 24, 2008 5:23 pm
I would imagine that every neck maker on the planet is snowed under making aftermarket coronado necks.
Yes the cat has opposing thumbs and extra digits.
DB
Post by DB » Mon Mar 24, 2008 8:06 pm
Seriously, no one is making these.  You'd have to find a luthier who would make a neck to specs - assuming you can get someone to send you the specs.
DB
IV, V, VI, XII...
Post by the older brother » Tue Mar 25, 2008 1:01 am
an alternative is to by a paddle neck (half paddle with tuner holes drilled would be the easiest I guess) and shape it yourself - someone on the board may have a coronado that you can get a trace from.
I know that at least one (Jazzprod) have a frankenmaster with a Coro-neck.
You can also watch ebay - the coro necks don't go for that much (I think a custom ordered neck from a luthier would be much more expensive.)
mjet
Post by mjet » Wed Mar 26, 2008 5:51 am
the older brother wrote: an alternative is to by a paddle neck (half paddle with tuner holes drilled would be the easiest I guess) and shape it yourself - someone on the board may have a coronado that you can get a trace from.
+1
iodine74
Post by iodine74 » Wed Apr 02, 2008 7:36 pm
I definately don't expect anyone to carry them as a normal thing, but didn't know if maybe someone around here might know of someone who had one made.
Here is the guitar I was talking about
It was a refin I'm 99% sure... I just love the color.
rickenmetal
Post by rickenmetal » Mon Apr 21, 2008 10:48 am
If you just like the headstock shape you could probably get a CBS headstock neck (many available from different companies) and sand it down to look like a Coronado headstock.
