Me either, but it was only since I started going on forums, that I found out my guitars had so many problems that I needed to buy upgrades to fix them.adamrobertt wrote: ↑Tue Sep 29, 2020 6:08 amI've never had an issue with the old school butterfly style ones. Just me?
Mastery String Tree....
- MrJagsquire
Re: Mastery String Tree....
- alexpigment
Yeah I've also never seen a reason to upgrade from the standard vintage ones either. I've honestly never found a situation where there was binding from the string tree. Just make sure you have a post under it so it's not pulling the strings all the way down to the headstock, never use one for the D/G strings, and maybe put some vaseline under there once every few years. I'd just save the money and buy some strings that you know you'll eventually use
Don't get me wrong, roller string trees seem conceptually good, but I think they're just a device in search of a problem.
- alexpigment
I know this picture probably isn't yours, but I would bet that this string winding technique causes more tuning issues than a stock string tree ever wouldThePearDream wrote: ↑Tue Sep 29, 2020 7:18 amAnymore I always use Gotoh RG15/RG30 string trees. A fraction of the price of the Mastery, Gotoh quality, minimal footprint, no sharp edges, easy to retrofit, and easy to find.
- ThePearDream
Nope, not my pic, just one of the first ones I could find that showed it in use. But you're right about that winding job, that E is awful.alexpigment wrote: ↑Tue Sep 29, 2020 3:34 pmI know this picture probably isn't yours, but I would bet that this string winding technique causes more tuning issues than a stock string tree ever would
Doug
@dpcannafax
@dpcannafax
- GAZINGUK
Thank you for your replies. Personally, I've never had any problems with the string trees on any of my guitars; even with trem use. That particular piece of hardware is not something I think about. It's just there and does what it does.
I love Mastery products and the company has always been fair to me. For example, when things have gone missing in the post they have replaced them and given me the chance to buy other items for just under fifty percent of the normal price. I also love dealing with them directly, they have some nice people working at the company. I do use and recommend Mastery Vibrato units, but I prefer the Staytrem bridge. However, I can't fault the quality of any of their products.
To me the Mastery string tree seems like a rather novel item. A lot of thought has been put into the product and it’s could be considered over-engineered. I understand that it creates more downward pressure on the strings. I also think that it’s handy that you don't have to lubricate it, so that's good for tremolo use (as long as the nut is cut correctly and/or lubricated). I may try one out of curiosity more than anything, but I'm on the fence regarding the design. I’ve never cared for the look of the Mastery Bridge its saddles. Aesthetically I'm used to it/them more than anything. I suppose this is the only thing holding up the purchase at the moment. However, functionality always wins and if an improvement is achievable then why not try I suppose.
- HNB
Same. I don't use the tremolo much, but when I have them set up correctly on my strat, jazzy, etc, I never have an issue with the guitar going out of tune from tremolo use, so I don't see a need to change them. I have used a Mastery tree because I had one with a bridge and tremolo, but I don't seek them out. I find the cheap butterfly ones work just fine for me. I would rather put money into a nicer nut. That makes more of a noticeable difference to how a guitar sounds to me.MrJagsquire wrote: ↑Tue Sep 29, 2020 11:55 amMe either, but it was only since I started going on forums, that I found out my guitars had so many problems that I needed to buy upgrades to fix them.adamrobertt wrote: ↑Tue Sep 29, 2020 6:08 amI've never had an issue with the old school butterfly style ones. Just me?
Christopher
Lilith Guitars
Lilith Guitars
- mackerelmint
Just speaking to the "butterfly" style ones, and those have never given me problems. But the earlier style, the disc that has two slots underneath for strings, that type can be janky as shit if you're playing with a trem on there. They're made super cheaply and some are kinda sharp/jagged in places where your string runs, so even without a trem they could presumably cause problems. I used to get B strings breaking right underneath it if I wiggled the bar or even bent that string a lot.
Worth the dollar or two to fix.
- alexpigment
Yeah, I assumed were all on the same page about the *butterfly* ones, not the round ones. I think Fender realized their mistake around 57 and switched to the butterfly design, so I don't think there are any offsets with a round string tree to my knowledge.mackerelmint wrote: ↑Wed Sep 30, 2020 7:30 pmJust speaking to the "butterfly" style ones, and those have never given me problems. But the earlier style, the disc that has two slots underneath for strings, that type can be janky as shit if you're playing with a trem on there. They're made super cheaply and some are kinda sharp/jagged in places where your string runs, so even without a trem they could presumably cause problems. I used to get B strings breaking right underneath it if I wiggled the bar or even bent that string a lot.
- mackerelmint
Yeah, I think Fender did, but I've encountered them on other makes, for some reason. Cost, I guess. And Fender does break them out sometimes for some stupid reason that's almost certainly the fact that vintage purists will scream bloody murder about a period incorrect detail like a string tree that doesn't chew their B strings up or a neck volute that keeps their headstocks from snapping off constantly. Guitarists are a bunch of yowling cro-magnons sometimes, setting their huts on fire while they're still inside and stubbornly loving every minute of it. That style is on a bunch of CV Squiers, too, although admittedly better made than the string mangling originals.
- HarlowTheFish
TGP & TDPRI: "But that's how great-granpa George kept himself warm in the winter! These newfangled 'heater' things are bad for yer tones, gosh-darnit!"mackerelmint wrote: ↑Wed Sep 30, 2020 7:51 pmGuitarists are a bunch of yowling cro-magnons sometimes, setting their huts on fire while they're still inside and stubbornly loving every minute of it.
- echobaseone
I was getting a bit of buzz on my G and couldn't figure out why. I don't recall if that was my reason for buying THIS:
http://store.reverendguitars.com/product/triple-tree/
But it sure works. Might be worth a look?
- Snowmonkey
I was thinking of getting one of those to stop my "dead" open G string sound. But I was worried that the pressure of 3 strings on one screw might one day rip it out of the headstock. Unnecessary worry?echobaseone wrote: ↑Thu Oct 01, 2020 11:37 amI was getting a bit of buzz on my G and couldn't figure out why. I don't recall if that was my reason for buying THIS:
- adamrobertt
ridiculous concern lolSnowmonkey wrote: ↑Wed Nov 18, 2020 2:24 amI was thinking of getting one of those to stop my "dead" open G string sound. But I was worried that the pressure of 3 strings on one screw might one day rip it out of the headstock. Unnecessary worry?echobaseone wrote: ↑Thu Oct 01, 2020 11:37 amI was getting a bit of buzz on my G and couldn't figure out why. I don't recall if that was my reason for buying THIS:
- Snowmonkey
Yeah, thought so. I often overthink these things
- 2after909
I’ve got a mastery string tree on a jazzmaster. It’s good.
