I want to re-wire my jag, but I'm wayyyy too dumb to design a diagram on my own so I'm asking y'all for your help.
Here's what I want: https://imgur.com/a/58LeSAp
Can someone help me with a Jaguar wiring diagram?
- itzleb
- bodhi
Re: Can someone help me with a Jaguar wiring diagram?
You could probably have a look at the largest wiring thread on here http://www.offsetguitars.com/forums/vie ... 8&t=104282 . Also, essentially what you have is a split volume and tone two pickup guitar, with a three way toggle switch. Add a "master" series parallel switch to that mix, add the strangle, add the coil split. The vast majority of all guitar wirings are pretty much modular, meaning you can approach them separately.
Exactly this. I agree that many of the components are modular. Sometimes there's a trick to putting them in the right order though!bodhi wrote: ↑Fri Oct 09, 2020 11:43 pmYou could probably have a look at the largest wiring thread on here http://www.offsetguitars.com/forums/vie ... 8&t=104282 . Also, essentially what you have is a split volume and tone two pickup guitar, with a three way toggle switch. Add a "master" series parallel switch to that mix, add the strangle, add the coil split. The vast majority of all guitar wirings are pretty much modular, meaning you can approach them separately.
