The Dwarves dug too greedily and too deep. You know what they awoke in the darkness of Khazad-dûm...
So as you can see - I made some holes a little too deep - concerning shielding - would you rather:
a) fill the holes with some resin
b) ignore them and use copper-tape
I got shielding color at home but copper tape might be more effective in covering things up...
Also the pickguards are finished (I carved the bevel with a blade as the router misses the tool to make a bevel). Still can‘t decide whether to go with mint or black...
Shielding is done.
Next step is to wire that thing up:
What I have: Ruebezahl Wide Range Humbucker and Tele Bridge Pickup, 3 way toggle, 2x 2 way slide switches - 3 Pots
My plan would be to make the WRHB switchable from series to parallel and add a strangle (or a blower) switch and make it dual volume single tone.
Right now I have 3 1 Meg pots in it - one should be logarithmic and one linear - but the third one I can't tell - it says CTS 1000 1513 on it - and google wouldn't spit out what it is...
All the 72 custom and Telecaster deluxe wiring diagrams used 500k or 250k pots (which is probably the Mexican reissue from a few years back) - I also have one 250k pot (CTS 250V 137 1951) - and as I'm totally new to Telecasters - but I do know about their twang and bite attributes - should I go with the 250 in the Bridge position? or on the tone?
