RI Mustang project
ghostsurfer
RI Mustang project
Post by ghostsurfer » Wed Jun 18, 2008 5:27 pm
Well, I snagged this stang on CL, it was beat up pretty badly in a so called "Relic" attempt. I had to save it. I stripped it, tried to repair the damage and in the process of painting and buffing. I am using reranch paint. I did assemble it for a photo but I am not happy with the buff so I will probably take it apart again. Can't help it, never really happy with anything I paint.
Ninja Mike 808
Re: RI Mustang project
Post by Ninja Mike 808 » Wed Jun 18, 2008 8:30 pm
Looks really good, I woulda done some comp. stripes on it, but tha's jus me bein' silly...
What kinda paint did you use?
ohm-men
Post by ohm-men » Wed Jun 18, 2008 8:33 pm
Hmmm, looks nice. A very pretty colour. I like Mustangs in Sonic Blue or Dapne Blue a lot.
perhaps share a thing about the painting process, There's a lot of guys here who can help you out witht the buffing.
Down Underground
Post by Down Underground » Thu Jun 19, 2008 12:26 am
my 3 cents...I have refinished a few guitars and learned this....you must completely remove the old finish...away it must go...next sand the body smooth...then you need to apply a wood filler and seal the body....let dry a few days....next sand the body untill it's completely smooth!  no dings or anything like that...after shooting a few coats ( 5-7) of nitro let the body sit for a few weeks..the longer the better...a month is good....then comes the wet sanding! 600, 800, 1000. 1500, 2000 grit paper...be sure to use a sanding block! the paint should come alive around this time.  finish it off with some nitro clear coat. use the entire can....let the clear coat sit a few weeks! again the longer the better....repeat the wet sanding process and finish with some nice car wax!
ghostsurfer
Post by ghostsurfer » Thu Jun 19, 2008 6:31 am
Ninja Mike 808 wrote: Looks really good, I woulda done some comp. stripes on it, but tha's jus me bein' silly...
That is exactly what my plan was, I was going to lay the blue down and even bought the lake placid. Then my family saw the daphne blue one Dan Zane has (he is on playhouse disney)  and they all said "wow, do that to your guitar!"
here was my vision, I am 70% sure this is what I will do. opinions? Leave it?  Or competition stripes?
ghostsurfer
Post by ghostsurfer » Thu Jun 19, 2008 6:33 am
ohm-men wrote: Hmmm, looks nice. A very pretty colour. I like Mustangs in Sonic Blue or Dapne Blue a lot.
Well, I had drill attachment buff pads from stwmac, but I have bought a maguiars  auto buffer from porter cable, so I though it would do a real bang up job, since it is a DA and has adjustable rpm's.
ghostsurfer
Post by ghostsurfer » Thu Jun 19, 2008 6:34 am
Down Underground wrote: my 3 cents...I have refinished a few guitars and learned this....you must completely remove the old finish...away it must go...next sand the body smooth...then you need to apply a wood filler and seal the body....let dry a few days....next sand the body untill it's completely smooth!  no dings or anything like that...after shooting a few coats ( 5-7) of nitro let the body sit for a few weeks..the longer the better...a month is good....then comes the wet sanding! 600, 800, 1000. 1500, 2000 grit paper...be sure to use a sanding block! the paint should come alive around this time.  finish it off with some nitro clear coat. use the entire can....let the clear coat sit a few weeks! again the longer the better....repeat the wet sanding process and finish with some nice car wax!
Great info. Do u think Alder still needs a grain fill? I skipped that part
rickenmetal
Post by rickenmetal » Thu Jun 19, 2008 8:53 am
Competition stripes are usually on the contoured bodies, you seem to have the slab body 65 reissue. I don't much care for competition stripes, I like contoured bodies though, but that's just my opinion. In any case your guitar should be poplar and have better pickups than the earlier reissues.
Did the previous owner attempt to contour the top? Can't really tell from the pics. If he did, it wouldn't be original, but it adds to the playability.
Ninja Mike 808
Post by Ninja Mike 808 » Thu Jun 19, 2008 12:04 pm
You could even go opposite if you wanted to, like make the Lake Placid the comp stripe.
Nord
Post by Nord » Thu Jun 19, 2008 1:34 pm
Alder typically does not require grain filling. You'd be able to see and feel if that piece of alder's grain is (rare) open (in which case grain filling would be required)
sabisound.com
-2N3904-
Post by -2N3904- » Thu Jun 19, 2008 2:08 pm
Nord wrote: Alder typically does not require grain filling. You'd be able to see and feel if that piece of alder's grain is (rare) open (in which case grain filling would be required)
CIJ mustangs are basswood though.
rickenmetal
Post by rickenmetal » Thu Jun 19, 2008 2:24 pm
65 RIs are poplar, unless the specs are wrong.
-2N3904-
Post by -2N3904- » Thu Jun 19, 2008 3:54 pm
Oh yea, i forgot...some are poplar too. i think its the 69's that are basswood.
ghostsurfer
Post by ghostsurfer » Thu Jun 19, 2008 7:11 pm
Ninja Mike 808 wrote: You could even go opposite if you wanted to, like make the Lake Placid the comp stripe.
WOW, now that would be a cool look, not too original but very original :o does that make sense.
the previous owner attempted something with what looked like 36 grit!!!  :wtf: not sure if it was a contour attempt
Based on my Junior high shop classes, I'm gonna say it was poplar.  ::) but, that was a long time ago LOL
I do know that Ash needs filling   ???
