Hey guys my background is with Fender Jazz basses so I do not know exactly what I need to get a complete Jazzmaster guitar together. These are the parts I am getting but there are a few things I really dont know about. Please let me know what you think...
Obvious stuff - USACG Body & Neck, Lollar Pups, Tuners, Neck Plate, Nut for neck, Pickguard...
BRIDGE - Genuine Fender Jaguar/Jazzmaster bridge assy. Made in USA. Part# 005-4466-000
TREM- Genuine Fender '62 Jaguar/Jazzmaster USA
Do I need this with the trem too?
45. Fender Jazzmaster/Jaguar vibrato arm mounting receptacle, chrome plated. As found on American Vintage Series reissue guitars. This is the gizmo that bolts to the bottom of the whammy assembly and sticks up through the top of the plate to accept the whammy bar. HARD TO FIND! IN STOCK AT THIS MOMENT FOR IMMEDIATE SHIPMENT! NEW. GENUINE FENDER USA. EACH $16.99.
http://www.guitarpartsresource.com/hardware_other.html
BP-0427-010 VIBRATO SPRING KIT
FOR JAGUAR & JAZZMASTER
BP-0427-010
Tension spring, retainer, and bolt for Jaguar® or Jazzmaster® vibrato.
$4.99
Then there is this stuff,
WIRING KIT - http://www.acmeguitarworks.com/Jazzmast ... 49C155.cfm
005-4454-000 JAZZMASTER USA BRACKET
Genuine Fender replacement roller pot switch bracket for Jazzmaster guitar. Mounting screws included.
Angleas - 22. Fender Jazzmaster/Jaguar control knobs for mini pots, black anodized aluminum with edge knurling. As found on American Vintage Series guitars. NEW. GENUINE FENDER. EACH $9.
What shielding stuff do I need?
http://www.guitarpartsresource.com/elec ... shield.htm
or
http://www.angela.com/
24. Fender Jazzmaster shield plate, solid brass, fits to a cavity in the body under the rhythm circuit control plate. GENUINE FENDER NEW OLD STOCK PART! ONLY A FEW LEFT TO SELL. EACH $14.
25. Fender Jazzmaster Master Control Shield. NEW! This is the stamped brass 'pan' that goes between the lower and upper control cavity on the right side of the body. As found on USA Vintage Series Jazzmaster reissue. GENUINE FENDER USA. EACH $29.
Newb needs help with parts list for Jazzmaster Build
- Eagle Eyes
- theworkoffire
Re: Newb needs help with parts list for Jazzmaster Build
You don't need the spring assembly or the arm mounting - they're already included with the trem.
Shielding - if you go for the brass you'll need everything marked jazzmaster on the GPR page, two of the pickup plates.
Best thing to do is trawl through some of the projects on the Mods/Projects/Restorations board here - these are a good start:
index.php/topic,2766.0.html
index.php/topic,14178.0.html
Good luck!
Good luck!
- the older brother
Here's Fenders official list of what's in a Jazzmaster (AVRI 62):
http://www.fender.com/support/diagrams/ ... 00APg3.pdf
And here's the drawing/layout with the preferences from the list:
http://www.fender.com/support/diagrams/ ... 00APg1.pdf
- the older brother
Just to add:
- The wiring kit from Acme is pretty expensive - buy the parts from that kit-list elsewhere and you'll save a few $$.
- The bracket is needed.
- So are two of those roller knobs
- You need four pieces of brass shielding (2x pup shield, rythm cav., lead cav/"tub")
- also one alu pickguard shield.
- Eagle Eyes
thanks for the info, very helpful.
I think I will just line all the cavities with my own copper shielding tape like this,
index.php/topic,5608.msg117682.html#msg117682
which would be more then sufficient right? all the fender brass parts seem like a unneeded cost at this point for me and I am not trying to be vintage correct.
