Does anyone know the correct pot values for a Jazz Bass?
Orang Goreng
Post by Orang Goreng » Thu Sep 28, 2006 1:15 pm
...because I'd like to know as well. The several schematics I have don't list the values.
Thanks to Sookwinder's generosity, yesterday I ripped the EMGs out of my '73 JB and replaced them by Duncan stacked humbuckers. Because the EMGs worked with 25kOhm pots, I borrowed the pots from my Musicmaster (250 kOhm) and put them in the Jazz. Great sound, but the output is a bit lower than on my other bass (full humbuckers, so that's no surprise) and guitars (offsets).
So I wonder, are 250 kOhm pots standard issue for a JB, or does it come with 500k or 1M pots? And what about the tone pot?
TIA,
Z.
mjet
Re: Does anyone know the correct pot values for a Jazz Bass?
Post by mjet » Thu Sep 28, 2006 4:59 pm
250k pots are standard for Jazz Basses. Whether the "stacked" aspect of the Duncans calls for something different is another matter, though.
Orang Goreng
Post by Orang Goreng » Fri Sep 29, 2006 1:18 am
Thanks! The Duncan schematic shows no pot values, so I'm assuming the PUs are meant as direct replacements.
I've always had EMGs in that bass (they were in there when I bought it), so I didn't really know what to expect output-wise. The output is just a tad lower than, say, my jazzmasters, so I guess this could be the normal situation. In the mean time, I read a few reviews on HC, and there the slightly lower output is also mentioned.
