- Dr Tony Balls
The normal way of thinking about a momentary stutter switch might be to use a "push to break" switch, which basically severs the signal when you push it. If you cant find one of those you can use a "push to make" (i.e. the doorbell example) and use it to ground the output signal when you press it.
Instagram: thetonyballs
- epizootics
When wiring a kill switch, you actually want an OFF-(ON) switch to short your output to ground, thus keeping the circuit closed. If you simply open the circuit, like you would with an ON-(OFF) switch, you'll get that annoying 'something's not grounded' buzz every time you press it. This one really confused my when I decided I wanted a kill switch on the first guitar I ever builtGordon wrote: ↑Fri Jan 22, 2021 7:43 amI know they are momentary, but I always pictured then as OFF and then (ON) to activate the bell sounds. I'm probably missing something, but I can't see how they can make a sound if it's ON-(OFF), and therefore not powered when the button is pressed.s_mcsleazy wrote: ↑Fri Jan 22, 2021 6:24 amnope. they're momentary switches. you might have to look for a "push to break" instead of a "push to make"
To je dogovor! Same if you ever come to Lyon It'll have to be wine and andouillette, though.
- kifla
What kind of wood you used for the body here?s_mcsleazy wrote: ↑Fri Jan 22, 2021 1:16 amso my plans for the telemaster xii got pushed back (the bridge i have needs to have the body altered) but i had a back up plan in case of this. i had 2 telemaster builds i wanted to do and this is one of them.
i'm going to be going with a kinda dark orange colour. that neck is temporary, it's actually getting the neck and neck pickup from my bandmate's telecaster. i'm tempted to do orange over black so when the guitar wears, the black shows through.
I made myself a Telemaster few years back....but it's kinda abandoned because it' heavy as hell!
Body is alder...
What is the thickness of your TM body?
- s_mcsleazy
mine is ash. i like heavier guitars though. i dunno bout thickness though. it's about on par with my other 2 telemasters though.
- Scout
Electrically, doorbell type are non latching, normally open switches. You push it to complete the circuit, it doesn’t latch or hold that setting, you release it and it reverts to an open circuit.Dr Tony Balls wrote: ↑Fri Jan 22, 2021 8:06 amThe normal way of thinking about a momentary stutter switch might be to use a "push to break" switch, which basically severs the signal when you push it. If you cant find one of those you can use a "push to make" (i.e. the doorbell example) and use it to ground the output signal when you press it.
I don’t know about stutter switches, but this type could effectively act as a momentary kill switch, done quickly it will stttttuuuuter.
- Gordon
Ah, yes, I didn't think of that! Makes more sense now, thanks!epizootics wrote: ↑Fri Jan 22, 2021 8:39 amWhen wiring a kill switch, you actually want an OFF-(ON) switch to short your output to ground, thus keeping the circuit closed. If you simply open the circuit, like you would with an ON-(OFF) switch, you'll get that annoying 'something's not grounded' buzz every time you press it. This one really confused my when I decided I wanted a kill switch on the first guitar I ever built
Tant que tu lui sers pas de grattons...epizootics wrote: ↑Fri Jan 22, 2021 8:39 amTo je dogovor! Same if you ever come to Lyon It'll have to be wine and andouillette, though.
- antisymmetric
Pushing along a bit with the SD4/L clone- I'm using a kind of Firebird-ish raised centre section to get those bulky lumps of metal down out of the way a bit- works for me visually, and it also may be marginally easier not to hit the switches unintentionally. I have suspected that the body may need to be thinned down a few mms, and having the pieces mocked up on the front confirms it. I'll do some serious swiss cheesing of the body as well to get the weight down before the Formica goes on.
- SuperAxe
That is so cool. Is this a prototype, ie, will you make one from proper timber afterwards?antisymmetric wrote: ↑Sun Jan 24, 2021 12:33 amPushing along a bit with the SD4/L clone- I'm using a kind of Firebird-ish raised centre section to get those bulky lumps of metal down out of the way a bit- works for me visually, and it also may be marginally easier not to hit the switches unintentionally. I have suspected that the body may need to be thinned down a few mms, and having the pieces mocked up on the front confirms it. I'll do some serious swiss cheesing of the body as well to get the weight down before the Formica goes on.
- antisymmetric
Thanks! The plan is to do ply because that's what the originals are- like they could be cut out of an old Formica dining table. The ones I've seen have solid painted sides, this one will make a feature of the ply with red tinted clear on the edges. Basically leftover materials and ideas from this bench top:
- s_mcsleazy
- kifla
Now that I have a few split coil pickups.. I'm gonna need a geetar to put 'em on:
One of these days my CNC gonna be busy...
- s_mcsleazy
still need to fix some bits on the orange telemaster, gotta wait till it's dry before i can. figured i'd post some pics anyway.
this is the colour in sunlight. it's pretty bold
a quick mockup.
a quick mockup.
- SuperAxe
Love it.s_mcsleazy wrote: ↑Tue Jan 26, 2021 5:36 amstill need to fix some bits on the orange telemaster, gotta wait till it's dry before i can. figured i'd post some pics anyway.
a quick mockup.
That looks great Sean!!
- s_mcsleazy
the back needs some work but the rest is fine.
