I am so jealous of you. I've always wanted a thin-body 125.PorkyPrimeCut wrote:
Well hello!!
....I think I need to sit down....
More later.....
The ES-125T has arrived........
- dj_techa
Re: The ES-125T has arrived........
"If you tell on us were gonna tell on you, thats ninja code."
- flatfiver
Looks great!
Welcome to the club! Glad you're enjoying it.
Regarding the bridge - it shouldn't actually be glued on. It should normally just be held in place by the tension of the strings. Have you tried loosening them up a little?
The serial number you found sounds like a factory order number, S indicating 1959, the first 4 digits are the batch no., the last 2 are the number it was within the batch. So you got the 20th guitar from batch 1339.
What's the neck like - is it chunky?
- vibroverbus
+1flatfiver wrote: Regarding the bridge - it shouldn't actually be glued on. It should normally just be held in place by the tension of the strings.
- OffYourFace
It might seem 'stuck' due to the lacquer softening up at one time... on a very hot summer day...flatfiver wrote:
- PorkyPrimeCut
You know I'd never have thought it was just the tension that holds it. Sure enough though I slackened the strings & it moved back into place perfectly. The blemish has now gone. Haheey!flatfiver wrote: Looks great!Welcome to the club! Glad you're enjoying it.
Regarding the bridge - it shouldn't actually be glued on. It should normally just be held in place by the tension of the strings. Have you tried loosening them up a little?......
......What's the neck like - is it chunky?
Thanks a bunch for pointing that out!!
The neck is more or less the same as my JM, maybe a little chunkier.
