NGD: Guild M-120E...
pesdispenser
Re: NGD: Guild M-120E...
Post by pesdispenser » Tue Sep 29, 2020 9:24 am
PorkyPrimeCut wrote:
Tue Sep 29, 2020 4:14 am
I'm not particularly fussed about the installed pickup so I may remove it too. One of these days I'll buy a similar pickup to yours (I was thinking something by LR Baggs) which I could use on both my acoustics.
Where did you get the replacement bone saddle & did you have to resize it at all?
I got identical bridge pins to my Guild D50, knowing they use the same size pins on all their acoustics. These are the ones.
LENGTH = 30mm COLLAR DIAMETER = 5.3mm END TAPER DIAMETER = 4.5mm
Thanks! Will order a set. I had a luthier make up the nut and saddle.
