The strange and perverse fetish of open-back tuners
- Drill
Re: The strange and perverse fetish of open-back tuners
Everything that is not a locking tuner is just wrong. Closed back, open back, I don't care. As long as it's a locking tuner.
Yep.
- HarlowTheFish
Thirded. I get "vintage-accurate" when it's a reissue or a vintage axe, but for anything else? They're just better.
- ThePearDream
I have locking tuners on my acoustic
I have locking tuners on twelve acoustics.
Hey, a good idea is a good idea!
- papa_hotel_delta
I think the Waverlys use the Kluson footprint, don't they? I would go to Stew-Mac and check the measurements, but that's what I believe.papa_hotel_delta wrote: ↑Sun Jan 03, 2021 2:45 pmwhich ones? (tuners)
I would change the Waverlys on the Martin tomorrow if I didn't have to drill a hole.
Double check that, though.
- PorkyPrimeCut
Almost all modern replacement open-back tuners have mount holes situated around 25.5mm apart from each other. I seem to remember reading that older Klusons have a narrower distance.Larry Mal wrote: ↑Sun Jan 03, 2021 2:57 pmI think the Waverlys use the Kluson footprint, don't they? I would go to Stew-Mac and check the measurements, but that's what I believe.papa_hotel_delta wrote: ↑Sun Jan 03, 2021 2:45 pmwhich ones? (tuners)
The backplate on Klusons are a slightly different shape though so, if your Waverleys leave a tan line, it'll show, slightly.
Also, make sure you check the inner diameter of the tuner bushings that are on your Martin. If they don't match, or are narrower than Klusons, you'll need to make a change. Then, you'll have to check the outer diameter too.
- PorkyPrimeCut
This might help, although the Klusons in the diagram aren't the new "Prestige" line...
I have the "Prestige" ones so can give you any other measurements, if you need them.
