Need a favour: Gretsch info
- windmill
Hello
I'm trying to hunt down info about gretsch guitars.
Does anyone know if the website "The Gretsch Pages " is still active.The Google links i can find say the server is not found.
I have seen references to the site recently tho'
Any help will thanked for !
- sonik
- windmill
Re: Need a favour: Gretsch info
Thanks Sonik
But on clicking the link -
" page cannot be displayed"
"can't find server"
Any suggestions on why this may be ?
Perhaps the innernnet cable across the Pacific doesn't quite reach ?
"can't find server"
- missionguitars
+1 - a-ok here.
Maybe reset your IP? Are you looking from work, and it's not on the "approved" list of sites allowed?
MissionGuitars.com
"Like" me at https://www.facebook.com/missionguitars
- windmill
I'm internetting from home
Can you explain how to re-set the IP that you mention ?
Ta !
Ta !
- missionguitars
Never actually having done it before, I'm probably the last guy to ask!windmill wrote: I'm internetting from home
Ta !
That being said, I Google'd your problem, and it looks like you might also have a spy/ad ware problem. Do you run Ad-aware and/or Spybot? That might help...
MissionGuitars.com
- greyman
Click Start.
Select Run.
Type cmd
In the Command Prompt that appears type "ipconfig /release"
After a few seconds when the cursor reappears type "ipconfig /renew"
That should "reset your IP." Depending on the type of internet and who your provider is, it may cause you to loose connectivity. BUT you should probably be ok. I doubt this will work.
I would also try this:
Click Start.
Select Run.
Type cmd
ipconfig /flushdns
That might do it for you.
Select Run.
Type cmd
Click Start.
Select Run.
Type cmd
ipconfig /flushdns
At Work -or- Not Online
- windmill
Thanks for your help
I run the free version of AVG,spybot but I have been having trouble running th enew version of Ad-aware, it keeps getting stuck about 2/3 of the way through.
I'll give the resetting a go
Thanks again
Thanks again
