pad
Post
by pad » Sat Oct 24, 2015 7:19 am
kosmonautmayhem wrote:Super cool! Also love the body top contours.
This reminds me I have a very similar SG shaped guitar under a bed in pieces. I really need to get that thing together.
Looks like the same exact neck as yours. Mine is branded "Buddy"! Lol
oh man! that could be a neat couple
me as a father would be glad to let your marry my sg-daughter
Con-Tiki! wrote:it is cool.
a lot of those chrome pickups are actually singles, disguised as HB's. that could explain your impression of them.
aria's and conrads and a bunch of others used them.
when ill change strings, i think she needs a little thicker gauge ill get them apart and let you know
cmatthes wrote:Neat guitar, but in no way a "Lawsuit" guitar!
why that? because its not a close copy?
HorseyBoy
Post
by HorseyBoy » Sat Oct 24, 2015 12:44 pm
pad wrote:cmatthes wrote:Neat guitar, but in no way a "Lawsuit" guitar!
The term "Lawsuit guitar" gets thrown around a lot but, basically, not every Japanese guitar from the 1970s is a "Lawsuit" guitar. There was one lawsuit, Norlin (Gibson) v. Elger (Ibanez) in 1977, and it was settled out of court. Ibanez, Greco, Tokai, Burny and Fernandez are the best-known brands of the era, and they made some amazingly good guitars that were near to exact copies of Gibson and Fender guitars. That's the key: near to exact. Your SG has a bolt-on neck and a funky carved top. No one would ever mistake it for a Gibson. That doesn't mean it's not awesome.
pad
Post
by pad » Tue Oct 27, 2015 4:48 am
oh okay, than the term seems wrong!
pad
Post
by pad » Sun Dec 13, 2015 7:20 am
hey guys, the bridge that has been on there is a jazz bridge and moves around.
it hast been drilled for bridge posts but im not sure what to buy.
can anybody help me?
budda12ax7
Post
by budda12ax7 » Sun Dec 13, 2015 3:50 pm
Really nice.....
pad
Post
by pad » Mon Dec 14, 2015 12:30 pm
budda12ax7 wrote:Really nice.....
thanks
but no one?
spiffy chap
Post
by spiffy chap » Mon Dec 14, 2015 1:47 pm
pad wrote:hey guys, the bridge that has been on there is a jazz bridge and moves around.
No way to know what size the bridge posts holes are. You have to measure and make sure the bridge is gonna be able to intonate. You also need to know what bridge you wanna use. Nashville, ABR, etc.
pad
Post
by pad » Tue Dec 15, 2015 3:26 am
spiffy chap wrote:pad wrote:hey guys, the bridge that has been on there is a jazz bridge and moves around.
is there anything on the web that talks about pro and cons?
don't have a mind about bridges so far.
might stand for roller bridges because they go pretty good for offsets.
A BIG PRO would be a bridge cover
Drill
Post
by Drill » Fri Dec 18, 2015 4:02 am
That's one of the cons on the vintage japanese guitars, sometimes, it's hard to find replacement parts.
You have to measure the one you have, and search what are the standard measurements (see metric and inch).
See what you can do with what you have (maybe you can fit new saddles in your old bridge), and if it is worth to go the custom way (this means, drill the guitar for new holes and fill the old ones).
pad
Post
by pad » Fri Dec 18, 2015 4:27 am
Drill wrote:That's one of the cons on the vintage japanese guitars, sometimes, it's hard to find replacement parts.
The bridge isn't completely wrong, it intonates realy good and sounds sweet.
the only issue is that it moves around, maybe its the easiest way to fix it to fit some bridge posts under it?
(just thinking)
MKR
Post
by MKR » Fri Dec 18, 2015 8:49 am
seems like the bridge is a lot like the ones on gretsch hollowbodies as in it's not actually attached to the guitar, correct?
If so a lot of people just put some double sided take under those bridges. another home fix is to put some violin resin under the bridge (that's what i did as my wife has a violin). no biggy.
I would defniitely NOT put in bridge posts.
cool guitar by the way.
crianlarich
Post
by crianlarich » Wed Nov 04, 2020 8:49 am
Hey, I joined the club!
it still is with a mockup of a pickguard. So it used to be more common to have them in two pieces? (Separate tenon piece?)
any ideas where it might have been built? hardware is marked "Jin Ah".
what's odd? 25,5" scale! I did a full pocket shim, neck straightness still isn't great, but o.k.
will move strap button from back to corner neck screw anyway - heavy + neck dive is quite annoying.
Pop is the most wonderful music – as long as it's played with three basses, a string section, and two french horns going "Vroop-Vrooo".
Veitchy
Post
by Veitchy » Wed Nov 04, 2020 2:09 pm
Swoopy body. German carve. Bigsby.
I dig it.
