fonzie
Post
by fonzie » Mon Feb 04, 2008 4:57 pm
So ive been really wanting one of those melody makers that are extra cheap, and ive been wonding if it would be possible to put one of these on it?
http://www.marshallparts.com/products/9 ... Nickel.htm
Basically im wondering if you would have to take the existing wraparound bridge off or leave it on like how it is on this
http://img225.imageshack.us/img225/6848 ... kerjd8.jpg
I'm also wondering if the tailpieces on the epiphone riviera's or the ones on the casinos only fit on semi/hollow bodied guitars.
Thanks
BenHagerty
Post
by BenHagerty » Mon Feb 04, 2008 4:59 pm
I am not sure, but that is a really good idea haha
chrisjedijane
Post
by chrisjedijane » Mon Feb 04, 2008 5:03 pm
re: The wraparound bridge - yeah, it's fine using the vibrola with the bridge on the melody maker.
re: riviera/casino tailpiece - They'll fit on other guitars, but it depends. What were you thinking about doing?
fonzie
Post
by fonzie » Mon Feb 04, 2008 5:08 pm
just wondering if those tailpeices would fit on soild bodied guitars since ive only seen them on semi/hollows
fonzie
Post
by fonzie » Mon Feb 04, 2008 6:43 pm
wonder how a MM would be with jag pickups....
soundhack
Post
by soundhack » Mon Feb 04, 2008 7:47 pm
you mean a trapeze like this?
http://www.stewmac.com/shop/Bridges,_ta ... piece.html
the melody maker body is 1 5/16" thick, the trapeze tailpiece is 1 3/8" deep, so it may hang over the back a little
you might have better luck with a rick trapeze tailpiece
as these are made for thinner guitars
soundhack
Post
by soundhack » Mon Feb 04, 2008 7:53 pm
i would guess that there's no shielding in the MM, as it uses stacked humbuckers. might be a bit too noisy with single-coils. i'd give the MM pickups a chance first. most gibson players i've heard say they're too thin - so they probably sound pretty good.
flatfiver
Post
by flatfiver » Mon Feb 04, 2008 9:01 pm
I've seen some trapeze tailpieces that were about 1/2-2/3 as long as the ones pictured above. Those would probably work better. I think maybe AllParts might have them.
fonzie
Post
by fonzie » Tue Feb 05, 2008 6:09 pm
That rick tailpiece isnt bad, i just can't find one anywhere.
This tailpiece looks like it might fit better than the trapeze one but it may still have some hanging off, which i bet isnt too much of a problem
http://www.allparts.com/store/tailpiece ... roduct.asp
Tremolo wise, im thinking a bigsby would probly be statistically better (correct me if im wrong) than the vibrola.
soundhack
Post
by soundhack » Tue Feb 05, 2008 6:17 pm
just google "rickenbacker parts" and you should be able to find one.
soundhack
Post
by soundhack » Tue Feb 05, 2008 6:35 pm
actually a search of trapeze tailpiece on ebay and you'll find a huge variety. the short one with the spaghetti wire should work fine on a MM
soundhack on Wed Feb 06, 2008 12:40 pm, edited 1 time in total.
Jaded
Post
by Jaded » Wed Feb 06, 2008 12:34 pm
Has anyone actually tried any of these reissuse melody makers? they look pretty promising.. as i've been wanting something less fender-ish for a while.. the cheap price and single coils make them quite tempting..
5L1V3R
Post
by 5L1V3R » Wed Feb 06, 2008 1:53 pm
I've always thought these melodymakers would be fun to customize, they're simple, cheap, and lightweight. That would be cool to put a pair of jag pickups in there
del
Post
by del » Wed Feb 06, 2008 5:35 pm
original issues melody makers were available with non-tailpiece vibrolas (i don't recall the correct name for this variety). Here is a current example on ebay.
http://cgi.ebay.com/65-VINTAGE-GIBSON-M ... dZViewItem
I think if there was a reissue of this double-cut variety it would be hard to keep me away, but the current one seems too much like a set-neck tele to me. And I like the bolt-on tele thank-you-very-much.
But... the MMs are cheaper than the MIM Fenders...
Also, someone mentioned stacked humbuckers in the meoldy maker - the Gibson website lists them as regular single-coils, which I think is accurate and corresponds with the originals.
