MOTORIK II - Final pics on page 21 - new owner!
k o y l
Re: MOTORIK II - basecoat on
Post by k o y l » Thu May 20, 2010 1:35 am
That's beautiful ! :'(
theworkoffire
Post by theworkoffire » Thu May 20, 2010 1:37 am
This was the penultimate clear coat - ran out on the next one. Just before this one I wet-sanded with naphtha and 600 grit to get rid of as much of the orange peel as I dared.
Lucky spider's leg - every finish should have one:
k o y l
Re: MOTORIK II - clearcoats and spider leg done
Post by k o y l » Thu May 20, 2010 3:30 am
That spider leg makes it the classiest build on the board ! 8)
(Let's not forget that somewhere in the world lives a 7 legs spider)
theworkoffire
Post by theworkoffire » Thu May 20, 2010 3:38 am
k o y l wrote:That spider leg makes it the classiest build on the board ! 8)
:whistle:
Last edited by theworkoffire on Thu May 20, 2010 3:53 am, edited 2 times in total.
Post by the older brother » Thu May 20, 2010 3:39 am
:whistle:
Maybe he's born with it - maybe it's Maybeline....
Post by the older brother » Thu May 20, 2010 3:44 am
At least you didn't get as much trouble with spiders as Ibanez did in the 80's:
theworkoffire
Post by theworkoffire » Thu May 20, 2010 3:50 am
Ooooof! Nasty. I should have gone for one of these inlays - http://www.luthiersupply.com/scarypage.htm
Mr. Peabody
Post by Mr. Peabody » Thu May 20, 2010 5:36 am
Wow. I love that color.
spacewhale
Post by spacewhale » Thu May 20, 2010 7:30 am
let me guess, The Leg (probably the most talked about dismembered spider's leg in the world at this time) is right in the middle of somewhere that won't be covered by the pickguard/hardware?
If so that's unlucky...
...if we take the disabled spider out of the picture...
...and other bad things... :mellow:
theworkoffire
Post by theworkoffire » Thu May 20, 2010 8:41 am
I'm not sure 'disabled' is quite the word I'd use...
And yes, of course it's right in the middle of the back - half way through all my spraying everything in my shed got covered in tiny baby spiders, so it's a miracle there aren't more. I tried to sand it out but it was too close to the metallic basecoat to dig out without consequences. Looks big in the pic, but it's only about 3mm long so it's fine.
crazyzeke
Post by crazyzeke » Thu May 20, 2010 8:49 am
I wonder if that's one of the legs of the spider from mars.
The Offset Trio
2003 CIJ Fender Jaguar, Sunburst (heavily modified)
2022 MIM Fender Meteora, Cosmic Jade (top mounted input jack added)
2024 CIC Squier Contemporary Jaguar HH ST, Skyburst (stock)
theworkoffire
Post by theworkoffire » Thu May 20, 2010 9:38 am
You have a spider in your arse??
Echo Ranch
Post by Echo Ranch » Thu May 20, 2010 9:42 am
hahaha. good one!
reverb
crazyzeke
Post by crazyzeke » Thu May 20, 2010 11:29 am
theworkoffire wrote:You have a spider in your arse??
That's a weaksauce response to a wry Bowie reference, Ben. Better luck next time! :P
Back on topic anyway, is it just the photography or is the finish significantly less green now? Looks like it had a shade of battleship gray mixed in.
The Offset Trio
theworkoffire
Post by theworkoffire » Thu May 20, 2010 12:32 pm
Yeah, I added a load of white pigment and some black lacquer here to grey it down. It's actually a bit greener than it looks in the pics, at least on my screen, but it's nothing like the cow-pleaser it was.
