Is 10° the Offset Golden Rule? (Unsettling photos ahead!)
Re: Is 10° the Offset Golden Rule? (Unsettling photos ahead!)
Post by RumorsOFsurF » Sun May 27, 2007 3:33 pm
If you have an amp with two inputs, you can plug both in!!
k o y l
Post by k o y l » Sun May 27, 2007 3:55 pm
Yes but I only have one !
It Would be possible to use an A/B box as well..
It's not usable to let it plugged all the time since it amplifies every little sound of the guitar... It needs carefullness (does this word exists ??) to use it but you can achieve really cool sounds:  for exemple, gently hitting the strings behing the nut with a drum stick give sounds close to John Cage's prepared piano pieces.. :-*
SPudnik
Post by SPudnik » Sun May 27, 2007 5:22 pm
Frank Zappa had a heavily modified giutar with contact pickups
in the neck.
It sounded like a combination of giutar and bedsprings...
Pretty cool - for the novelty stuff.
Bass VI - A What?
k o y l
Post by k o y l » Sun May 27, 2007 5:55 pm
I didn't know about that !
I'll try to find infos on this guitar, it might be interesting. 8)
