Time to come clean about why I'm asking for measurements etc.....
- Orang Goreng
Re: Time to come clean about why I'm asking for measurements etc.....
Maybe you can do something with this picture I just took of my MM. What you want to find out is the distance between the saddles and the leading edge of the bridge. If someone could compare this to their XII, we could check how interchangeable the bridges are.
It seems like I'm pushing you into using an MM bridge, doesn't it?
- mjet
That certainly seems to be the most logical way to go, IMHO. Basically the same shape, easy to get a hold of, etc.Orang Goreng wrote:
- Orang Goreng
Just look at how much travel there's left for the saddles if you move them back. I think it should be possible even if the saddle-leading edge distance is much greater on a XII bridge.
- zhivago
hehe...anything that saves money is great...I'd definetely use the MM bridge if it fit for sureOrang Goreng wrote: Maybe you can do something with this picture I just took of my MM. What you want to find out is the distance between the saddles and the leading edge of the bridge. If someone could compare this to their XII, we could check how interchangeable the bridges are.
hopefuly someone (Marc maybe?) could measure the saddle distance....
- i love sharin foo
You could use a Jazzmaster body with a normal JM bridge as a reference point for placing the new bridge. Like Dr. Zai said, you can use the saddles themselves on both bridges as the sync point, and then line the new one up. I think this is an awesome projectzhivago wrote: I getcha now!
yeah, I filled in the pickguard gap on another pic of the Maverick and the pickguard's end looked too square....
hmmm....it's so weird that the particular XII bridge is not available as an aftermarket part
I'll fire up photoshop again tonight...it's just a bit like flying blind though....I don't really know exactly where to place any of the potential bridges on the mockup....
Justin
Goddamn this is real
- zhivago
good point there, Justin
I totaly agree...if this pans out like the photoshop mockup, then it'll be a really cool guitar...I should be designing for Fender!!
mind you, they would all be offsets!!!
- matthew
(Sorry, it is simply too hot for me to do anything as energetic as take a nice picture of the bridge right now)Orang Goreng wrote: Maybe you can do something with this picture I just took of my MM. What you want to find out is the distance between the saddles and the leading edge of the bridge. If someone could compare this to their XII, we could check how interchangeable the bridges are.
From the back of the bridge to the front is 53mm, from the saddles to the front, between 15 and 20mm
If I get a chance in the next couple of days, I'll take a picture of the bridge with a ruler in it for scale.
- matthew
Ok, the cool change has arrived, so I've done some pictures...
- Orang Goreng
That settles it then. The saddles on the MM can easily travel 10 mm back. It would look a bit odd with the intonation screws sticking out in front, but if necessary these can always be sawn off.
- zhivago
Orang Goreng wrote: That settles it then. The saddles on the MM can easily travel 10 mm back. It would look a bit odd with the intonation screws sticking out in front, but if necessary these can always be sawn off.
my god I love this forum!
I really do!!
it really is settled...the MM bridge will work, and the scale will be correct!
this just saved me $$$$$$!
thank you all very much!!!
- zhivago
ok...been thinking long and hard about alternatives and changing the actual design in order to drop the cost.
the bridge and also the pups are gonna be expensive, and after looking at pics of the Custom/Maverick, and also Mustang guitars, I've modified it to this:
- zhivago
intonation and bridge positioning could be a problem...as a first solution, I thought of turning the bridge round, and pushing the lip facing the tail-end down, so I can get the actual saddles to travel further backwards.
if that doesn't prove sufficient, I might actualy use a floating bridge, so it'll all intonate ok.
this will considerably drop the cost of a bridge + the hassle of unloading the canibalised Strat XII.
- Coronado
Well I have to tell the truth.
I was asking for the control plate and pickguard tracings because I have a similar proyect, the only diference is that I'll use a JM tremolo. So it would be a JM with a XII pickguard and control plate.
This way I'll have the XII look AND the tremolo. I don't have an image but I think you can imagine it.
John, I'm sure this way is easy for you to get the parts, but I don't like much the mustang tremolo... Sure it looks good, but I didn't like it when I had my Mustang.
- zhivago
what I wanna do basicaly is totaly decide on the tremolo piece once I have most of the pieces...I'll take the unfinished body, put the pieces on (before routing or anything) and draw the outlines to see where everything goes...
I've had a Mustang before and was ok with the tremolo...I made mockups of the same guitar with a JM tremolo, and I dunno...it just didn't look right to me...
either way, we'll end up with some cool guitars man!
next pieces for me to buy is the pickguard, the mustang tailpiece, and then the body, so I can start figuring out things in a more hands-on situation.
photoshop mockups are cool, btu getting the pieces in front of me will be great help in deciding how to go about this project.
what I know for sure, is that I don't want to give up on it because of the XII bridge rarity....
I still am not set on using XII pups or plain single coils either....so I guess I'm just throwing ideas out in the open....
- DarrelT
The Mustang trem isn't going to be that close to the pickguard if you're planning on staying with the standard size XII pickguard.
There will be a gap just like the Custom/Maverick.
