That's a chonky boi!
JAG-STANG Prototype - Reverse Engineering
- GilmourD
- AcrylicSuperman
- Emil
Re: JAG-STANG Prototype - Reverse Engineering
I made some mistakes with my digital caliper measuring the neck depth, so I took them again. Now they are 100% accurate.AcrylicSuperman wrote: ↑Tue Apr 09, 2024 7:53 pmWow! That is definitely the chunckiest MIJ I've probably ever encountered! Thanks for the info.
Nut width: 1.60
1st fret depth: 0.85"
1st fret width: 1.63"
12th fret depth: 0.93"
12th fret width: 2.03"
- GilmourD
OK, that makes much more sense, although I would love that chonker with your original measurements. LOLEmil wrote: ↑Wed Apr 10, 2024 12:14 amI made some mistakes with my digital caliper measuring the neck depth, so I took them again. Now they are 100% accurate.AcrylicSuperman wrote: ↑Tue Apr 09, 2024 7:53 pmWow! That is definitely the chunckiest MIJ I've probably ever encountered! Thanks for the info.
Nut width: 1.60
- AcrylicSuperman
Thanks for the update!Emil wrote: ↑Wed Apr 10, 2024 12:14 amI made some mistakes with my digital caliper measuring the neck depth, so I took them again. Now they are 100% accurate.AcrylicSuperman wrote: ↑Tue Apr 09, 2024 7:53 pmWow! That is definitely the chunckiest MIJ I've probably ever encountered! Thanks for the info.
Nut width: 1.60
- Emil
I meassured my 1996 MG69 Mustang as well:
Nut width: 1.58"
1st fret depth: 0.82"
12th fret depth: 0.90"
Compared to my 1995 Jagstang around 0.02-0.03” slimmer, but in reality it’s almost impossible to feel a difference between the two necks. I wouldn’t be surpriced if the difference is an effect of the sanding process on the individual necks in the factory rather than differences in specs between models.
Nut width: 1.58"
- Amon 7.L
Thank you for the measurements, Emil.Emil wrote: ↑Wed Apr 10, 2024 11:49 pmI meassured my 1996 MG69 Mustang as well:
Nut width: 1.58"
Yeah, the deviations are the result of the human operator during the process, it's clearly stated in Fender service diagrams:
(I just realised this is post number 666 )
- BTL
I think an argument can be made that the MIM Jag-Stang is closer to the likely or ideal spec than other versions might have been, but we'll never know for certain until the Blue Prototype is measured. Am I correct on this?Amon 7.L wrote: ↑Thu Apr 11, 2024 1:39 amThank you for the measurements, Emil.Emil wrote: ↑Wed Apr 10, 2024 11:49 pmI meassured my 1996 MG69 Mustang as well:
Nut width: 1.58"
Owner, Lowe Custom Guitars
- Amon 7.L
BTL wrote: ↑Thu Apr 11, 2024 5:35 amI think an argument can be made that the MIM Jag-Stang is closer to the likely or ideal spec than other versions might have been, but we'll never know for certain until the Blue Prototype is measured. Am I correct on this?Amon 7.L wrote: ↑Thu Apr 11, 2024 1:39 amThank you for the measurements, Emil.Emil wrote: ↑Wed Apr 10, 2024 11:49 pmI meassured my 1996 MG69 Mustang as well:
Nut width: 1.58"
Unless you know something we're not aware of, NO. YOU ARE NOT CORRECT.
- BTL
Somewhere in the distant past I thought I remembered the MG69 neck was the closest newer production model, and it looks pretty close to the MIM Jag-Stang. Perhaps I mis-remembered. Maybe those were the 2.0 prototypes?
- AcrylicSuperman
They did throw a MG69 neck on red 2.0. We know that blue never got such treatment.
- BTL
Ah! That's the detail I got confused about...thank you!AcrylicSuperman wrote: ↑Thu Apr 11, 2024 9:25 amThey did throw a MG69 neck on red 2.0. We know that blue never got such treatment.
So, the MIM neck is faithful to the MG69 used on red 2.0. I wonder if that's what they used as the baseline for the MIM reissue. I apologize if the details are a little fuzzy for me at this point.
- AcrylicSuperman
I don't believe they evem used the MG-69 as the baseline for the MIM either. They have similarities but aren't the same either. Each variation of the Jagstamg has had a different neck.BTL wrote: ↑Fri Apr 12, 2024 7:36 amAh! That's the detail I got confused about...thank you!AcrylicSuperman wrote: ↑Thu Apr 11, 2024 9:25 amThey did throw a MG69 neck on red 2.0. We know that blue never got such treatment.
