Fender Bassman Blackface Head
- sadbirthdays
Has anybody ever tried putting a reverb tank in theirs?
- Horsefeather
Re: Fender Bassman Blackface Head
It takes more tubes to drive reverb so that's a major operation. Easier to just get a Twin Reverb and revoice it to Bassman specs, I reckon.
That or get an outboard spring reverb unit.
- spiffy chap
I just use a reverb pedal or my RE201’s spring. Never had the desire to mod mine.
1966 Blackface Bassman
- spiffy chap
- muchxs
You're trying to make a cat do dog tricks.
Fender style tube driven reverb requires both sections of a 12AT7 for the drive side, a small driver transformer then 1/2 of a 12AX7 on the recovery side.
It could be done if you were willing to assimilate one of the channels for the reverb circuit. Still, it's a vintage amp and kinda rude to modify it.
Modifying a vintage Fender usually kills any resale value it might have had.
Yeah, this is how I feel about it.muchxs wrote: ↑Mon May 21, 2018 3:57 pmYou're trying to make a cat do dog tricks.
If you found a Bassman that was in complete need of a rebuild, like a flood-damaged one or something, then sure, mod away. But at that point, why not just buy a kit and experiment on a new build instead?
Mucking with a perfectly functional blackface amp just seems sacrilegious.
- Igorilla
+1mbene085 wrote: ↑Mon May 21, 2018 5:21 pmYeah, this is how I feel about it.muchxs wrote: ↑Mon May 21, 2018 3:57 pmYou're trying to make a cat do dog tricks.
Besides being a major surgery circuit-wise you'll still have to deal with the ptoblem of hum caused by a pretty small head cab if you decide to install the reverb pan into the head cab. The transformes will be very close to reverb pan's transducers (hum city!). There is good reason why the piggy-back amps with reverb, like bandmaster reverb and showman reverb, have quite big head cabs.
A good solution, if you don't want a tube driven outboard reverb unit, is a SurfyBear Reverb kit. Install the reverb pan under your pedal board, put the circuit board in a small hammond enclosure, connect and you are done. This is going to give you a real spring reverb with a lot of adjustability.
- bryan83taco
I highly recommend a Fender 6G15 outboard Reverb unit. They are magical, much better than their onboard tanks IMO. Expensive but so worth it!
- i love sharin foo
That's the ticket! I've been using a '65 for the last 13 years and there's no comparison. With the prices of blackface Fenders steadily climbing, it is also the smarter way to go IMHO. Plus they look great stacked upbryan83taco wrote: ↑Sun Jun 10, 2018 8:58 amI highly recommend a Fender 6G15 outboard Reverb unit. They are magical, much better than their onboard tanks IMO. Expensive but so worth it!
A death’s head ring upon his finger
- bryan83taco
Killer combo! I also got a sweet ‘65 Reverb and a ‘67 Bandmaster. Love that blondie you got!i love sharin foo wrote: ↑Thu Jun 14, 2018 4:36 pmThat's the ticket! I've been using a '65 for the last 13 years and there's no comparison. With the prices of blackface Fenders steadily climbing, it is also the smarter way to go IMHO. Plus they look great stacked upbryan83taco wrote: ↑Sun Jun 10, 2018 8:58 amI highly recommend a Fender 6G15 outboard Reverb unit. They are magical, much better than their onboard tanks IMO. Expensive but so worth it!
- i love sharin foo
Thanks!bryan83taco wrote: ↑Sat Jun 16, 2018 8:10 pm
I bought the '65 Reverb Unit and '64 Bandmaster from the same place at the same time. They've been paired up for a long time now
I think blackface Bandmasters are still kind of under appreciated at this point. Sure, they're thinner compared to a Bassman with it's bigger output transformers, but they just WORK! I've always loved mine. I did own a super clean '65 Bassman at one point and wish I would've kept it though.
