Mellotron micro
- pocaloc
Mellotron micro
I’ve been looking at these lately since they’re priced at $950. I’m a total keyboard beginner but I know I would be obsessed enough with a mellotron that I would learn and play it a lot. Strawberry Fields Forever is my favorite song and I love a lot of mellotron sounds. Anyway I’ve looked at the mini off and on, but given my skill level, I don’t want to drop $2,000 on one. Does anyone have any opinions on the micro? Is a two octave keyboard a good place to start for a beginner, and most importantly could I learn to play Strawberry Fields Forever on it?
- jthomas
Re: Mellotron micro
If you are just wanting to experiment and try something our before really diving in you might consider software first:
https://www.gforcesoftware.com/products/m-tron-pro
An inexpensive keyboard with MIDI connectivity and a MIDI in and out cable and you are ready to go. I'll bet that you would be under $300 even if you had to buy the keyboard.
- bluenote23
Re: Mellotron micro
As a keyboard player, I would say you can't do a lot with only two octaves. If I was recording tracks and wanted to add some stringy flavor then sure, two octaves would be fine but if I wanted to explore the potential of keyboards in general, then two octaves is pretty limiting.
It does depend a lot on what you are looking to do. If you want to add mellotron tracks to your projects, then this would be fine. If you really want to explore what keyboards and keyboard playing are about, then jthomas's suggestion is probably a wiser choice.
I just took a look at the mini and it has a 3 octave keyboard, at least the one I saw. Three octaves is still pretty limiting but that is enough to play the Strawberry Fields part (if the Youtube tutorial on the part is correct).
- pocaloc
Re: Mellotron micro
Thanks for the responses. In general I would be using it to color to things and maybe making stuff up. I appreciate the information.
- Zork
Re: Mellotron micro
Get a Waldorf Blofeld Keyboard. It can do very good Mellotrons and so much more and is priced at ~400 used.
- pocaloc
Re: Mellotron micro
Thanks for the tip. I’ll check it out.
- mediocreplayer
Re: Mellotron micro
This. You can get 61-key controllers for like $100-150. The good thing is that you can get a soft synth version of all the instruments your heart desires which 99% of the time sound the same than pretty much all hardware solutions.jthomas wrote: ↑Sat May 19, 2018 11:08 amIf you are just wanting to experiment and try something our before really diving in you might consider software first:
The downside of course is that there is an immediacy to just turning on the thing and playing it which is difficult to replicate when a computer is involved.
- mediocreplayer
Re: Mellotron micro
I actually took my own advice and bought the M-tron rack extension from the Propellerhead Shop.
So much fun. I can easily see myself lost for hours playing with this (and yes, it does Strawberry Fields
- fortytwo
Re: Mellotron micro
With three octaves you're still getting a couple more keys, than Macca had to play Strawberry Fields on.bluenote23 wrote: ↑Sat May 19, 2018 11:26 amI just took a look at the mini and it has a 3 octave keyboard, at least the one I saw. Three octaves is still pretty limiting but that is enough to play the Strawberry Fields part (if the Youtube tutorial on the part is correct).
- pocaloc
Re: Mellotron micro
There is actually a mini and a micro. The mini is three octaves and $2000 and the micro is two octaves and $1000. Just FYI.fortytwo wrote: ↑Tue May 22, 2018 10:24 amWith three octaves you're still getting a couple more keys, than Macca had to play Strawberry Fields on.bluenote23 wrote: ↑Sat May 19, 2018 11:26 amI just took a look at the mini and it has a 3 octave keyboard, at least the one I saw. Three octaves is still pretty limiting but that is enough to play the Strawberry Fields part (if the Youtube tutorial on the part is correct).![]()
- fortytwo
Re: Mellotron micro
I know. I'm doing a tour at the moment, with 2 mini's and a rack version, and we've talked about getting a micro as a spare.pocaloc wrote: ↑Tue May 22, 2018 7:56 pmThere is actually a mini and a micro. The mini is three octaves and $2000 and the micro is two octaves and $1000. Just FYI.fortytwo wrote: ↑Tue May 22, 2018 10:24 amWith three octaves you're still getting a couple more keys, than Macca had to play Strawberry Fields on.bluenote23 wrote: ↑Sat May 19, 2018 11:26 amI just took a look at the mini and it has a 3 octave keyboard, at least the one I saw. Three octaves is still pretty limiting but that is enough to play the Strawberry Fields part (if the Youtube tutorial on the part is correct).![]()
- redchapterjubilee
Re: Mellotron micro
For years I've used either M-Tron on the laptop or an E-Mu Vintage Keys unit. Last week I was finally able to use the Mellotron app on my iPad played from my Microbrute and it worked like a charm.
- rkharper
Re: Mellotron micro
I own the micro, and probably the very first commercially available M4000D (serial number 10).
I'm also totally uncapable of playing keys, but the Mellotron is very forgiving in that regard
I got my micro, that I can play the recorded parts and intros live, without hauling the big ass Mello to the stage, as I'm primarly a bass player.
nope, not limiting, a real Mellotron has only 37-keys, not a single key more. means: when you hit the octave switch on the micro to left, or right, there will be always missing notes on the lower side when octave down, and missing notes on the higher side when octave up.bluenote23 wrote: ↑Sat May 19, 2018 11:26 amI just took a look at the mini and it has a 3 octave keyboard, at least the one I saw. Three octaves is still pretty limiting but that is enough to play the Strawberry Fields part (if the Youtube tutorial on the part is correct).
Re: Mellotron micro
Cool little Mellotron rkharper! Not to derail, but what's the bass? REALLY sweet looking
- OffYourFace
Re: Mellotron micro
Serek Basses in ChicagoShadoweclipse13 wrote: ↑Wed May 30, 2018 1:00 amCool little Mellotron rkharper! Not to derail, but what's the bass? REALLY sweet looking![]()
https://www.serekbasses.com
