Walnut Telecaster
HNB
Walnut Telecaster
Post by HNB » Sun Sep 20, 2020 1:53 pm
I found this walnut body cheap on ebay and thought it would be fun. It was like $60. It is probably seven or eight pieces of wood pancaked and such, but looks pretty enough to me and I had some spare parts not being used.
ImageIMG_20200905_180849 by Christopher Louck, on Flickr
ImageIMG_20200905_180832 by Christopher Louck, on Flickr
I used some putty on the back to help fill in those seams.
ImageIMG_20200905_181838 by Christopher Louck, on Flickr
Then I got to work sanding it. With 300 grit it started to almost sand it to a polish. Never seen that with wood before. It was really cool. I guess that is because walnut is such a hard wood.
ImageIMG_20200906_145320 by Christopher Louck, on Flickr
I tried out a new painting method where I mix one scoop oil poly with one scoop mineral oil to thin it and wipe it on. It is like water thin so the wood sucks it up. Also because it is so thin, there is no wipe marks to sand out.
Image2020-09-06_04-03-48 by Christopher Louck, on Flickr
It also dries in like 10-30minutes to do another coat. I think I ended up doing five coats or so? Since walnut is so hard it was mostly just to darken it and make it more glossy. Then I loaded parts on. Seymour duncan pickups and old school cloth wiring and such.
ImageIMG_20200918_135917 by Christopher Louck, on Flickr
Going to use a different guard than this, but it will have a Costello vibe.
ImageIMG_20200918_141850 by Christopher Louck, on Flickr
The neck is a WD one that I made a custom decal for and installed Gotoh tuners. :)
ImageIMG_20200916_093157 by Christopher Louck, on Flickr
ImageIMG_20200918_141645 by Christopher Louck, on Flickr
ImageIMG_20200918_141655 by Christopher Louck, on Flickr
Christopher
Lilith Guitars
HNB
Re: Walnut Telecaster
Post by HNB » Wed Sep 30, 2020 5:41 pm
All done. Only thing that sort of bugs me is the neck pickup is wood mounted and the guard is for guard mounted, but it is pretty minor really. ;) Pickups sound good. It is heavy, but since it is a tele size body, it isn't too bad. The neck is a soft "V" on the back. I need a string tree, but otherwise all done. :D
ImageIMG_20200930_182245 by Christopher Louck, on Flickr
ImageIMG_20200930_182255 by Christopher Louck, on Flickr
ImageIMG_20200930_182259 by Christopher Louck, on Flickr
ImageIMG_20200930_182323 by Christopher Louck, on Flickr
ImageIMG_20200930_182330 by Christopher Louck, on Flickr
Christopher
Lilith Guitars
mediocreplayer
Post by mediocreplayer » Wed Sep 30, 2020 7:54 pm
Very nice! I call dibs on this when you sell it. It will make a good beater companion when I want to keep my Walnut Jag safe.
Veitchy
Post by Veitchy » Wed Sep 30, 2020 9:13 pm
Man that looks great - a tad more refined look for a Telecaster. So much walnut content lately. Hope the trend keeps up.
paul56
Post by paul56 » Thu Oct 01, 2020 11:57 am
Nice Tele, but why can't you mount the neck pickup to the guard? Couple of screws and springs and you're golden.
HNB
Post by HNB » Thu Oct 01, 2020 12:59 pm
The holes in the pickup were smaller than traditional screw mounting holes and I don't have the right drill size to drill them out. :)
Christopher
Lilith Guitars
