1991 '65 reissue twin reverb.
Make it loud here.
Nickfred
Post by Nickfred » Tue Oct 06, 2020 11:21 am
Is there anything I should know? Was this a good year / a bad year?
Is it just twin reverb?
Larry Mal
Re: 1991 '65 reissue twin reverb.
Post by Larry Mal » Tue Oct 06, 2020 11:22 am
They are very good amps.
Nickfred
Post by Nickfred » Tue Oct 06, 2020 11:36 am
Larry Mal wrote: ↑
Guess that's the only reply I need. 😎
Larry Mal
Post by Larry Mal » Tue Oct 06, 2020 12:38 pm
I think they were still made in the US at that point, if that matters.
Not sure what to say... they aren't quite point to point wired boutique amps or anything, but they sound great. They are Twins, which are always amazing sounding amps. Those reissue amps are of high quality.
andy_tchp
Post by andy_tchp » Tue Oct 06, 2020 2:11 pm
1991? Not to dissuade you, (but...) those are the first 'reissues' based around PCB construction, which will make servicing/repairs more difficult when compared with a Silverface equivalent built around a turret board with flying leads. Pots and jacks are on a secondary PCB, but the tube sockets are chassis mounted at least.
You'd hope PCB assemblies are still readily available as replacement parts from Fender.
It's crazy to think these things are now approaching 30 years old.
Assuming this is an amp you're looking at purchasing, does it come with a clean bill of health from an amp tech and/or any kind of short term (say 3 month) warranty? Have the electrolytic capacitors been replaced at any stage in the last 29 years?
Nickfred
Post by Nickfred » Tue Oct 06, 2020 9:04 pm
andy_tchp wrote: ↑
No idea. Will have to ask.
Would you rather go for a 2014 model then?
andy_tchp
Post by andy_tchp » Tue Oct 06, 2020 10:05 pm
Nickfred wrote: ↑
andy_tchp wrote: ↑
I... wouldn't buy either of them. But I already have an early '70s Vibrosonic Reverb, effectively a SFTR with a 15" speaker.
All of the above still applies aside from the question about electrolytic caps, as they'll be fine for a while being ~6 years in use.
Nickfred
Post by Nickfred » Wed Oct 07, 2020 2:22 am
andy_tchp wrote: ↑
Nickfred wrote: ↑
andy_tchp wrote: ↑
So you wouldn't buy a TR ever?
cestlamort
Post by cestlamort » Wed Oct 07, 2020 7:26 am
It comes down to dependability and price. The reissue twin reverbs sound great, but as circuit board amps, some repair and maintenance issues will be more difficult (and more expensive) compared with the older point-to-point amps. In other words, if you're planning on having it for a long time, it might make sense to look for an old silverface one (which will run forever) rather than one of the reissues. I'm not sure how the used market is in Denmark, but the SF amps seem to be roughly the same price as the '65 reissue ones in the US. (For example, I'm playing a SF Super Reverb that's older than I am and also had a twin reverb from the same era (which I miss). They sound great and there's no reason they won't outlive me).
All will be heavy and all will be loud and clean, varying some by year, etc.
Larry Mal
Post by Larry Mal » Wed Oct 07, 2020 7:37 am
Nickfred wrote: ↑
I think he's saying that he would quicker buy one of the older silver face Twins instead, and I can only imagine he would buy one of the even older blackface Twins quicker. Of course, that would cost a lot more.
I owned some silver face Fender stuff, it's very good.
I can't speak to the maintenance of the reissue Fenders, but I have owned a couple. I suppose I own one now, and it is in fact a bit of a lemon, but it's a very weird model.
But the reissue Fender amps do sound very good, and they don't cost a whole lot, either.
Now, having said that, take a look at this video. Not only does it show pretty clearly the difference between Fender's expensive point to point wiring amps and the PCB stuff, but they A/B the two.
I was pretty sold on the more expensive amp by the end of it.
Nickfred
Post by Nickfred » Wed Oct 07, 2020 7:49 am
andy_tchp wrote: ↑
Nickfred wrote: ↑
andy_tchp wrote: ↑
So the electrolyte caps aren't a problem in a SF?
Nickfred
Post by Nickfred » Wed Oct 07, 2020 7:51 am
Larry Mal wrote: ↑
Nickfred wrote: ↑
Thanks I'll have a look.
Well I'm on a budget, so I have to think about that too.
Not gonna travel the whole world with it, so it isn't going to be bounced around.
Nickfred
Also my father's a trained radio technician, so I'm not too worried about repairs...
cestlamort
Post by cestlamort » Wed Oct 07, 2020 5:42 pm
Nickfred wrote: ↑
andy_tchp wrote: ↑
Nickfred wrote: ↑
Caps in a 1991 amp will probably need to be replaced if they haven't been yet. The ones from the 1970s amps also need to be replaced if original, but it has probably already been done (maybe more than once).
Nickfred
Post by Nickfred » Wed Oct 07, 2020 9:08 pm
Why is there a need to change the caps?
