Just trying to work out what might need doing to it if I get it. Cheers.
I remember the first time I got shocked touching the metal on an amp with the polarity switched the wrong way. It was not a pleasant sensation. LOLi love sharin foo wrote: ↑Thu Oct 29, 2020 4:35 pmThe cap in the bias circuit has been replaced and also the two resistors across the output tubes. If they've been sone somewhat recently and with appropriate values, it's probably good to go for a while. They are relatively inexpensive and easy to do yourself though, if not. Looks like the polarity switch is still hooked up. I would disable that if it were me also.
Hah! Yeah, it's no fun! My Bandmaster electrocuted me for about a decade before I finally took care of itHNB wrote: ↑Thu Oct 29, 2020 4:40 pmI remember the first time I got shocked touching the metal on an amp with the polarity switched the wrong way. It was not a pleasant sensation. LOLi love sharin foo wrote: ↑Thu Oct 29, 2020 4:35 pmThe cap in the bias circuit has been replaced and also the two resistors across the output tubes. If they've been sone somewhat recently and with appropriate values, it's probably good to go for a while. They are relatively inexpensive and easy to do yourself though, if not. Looks like the polarity switch is still hooked up. I would disable that if it were me also.
Thanks!
Oh yes, I sure did. Particularly a 240v model that doesn’t need a step down transformer!s_mcsleazy wrote: ↑Sat Nov 07, 2020 4:31 pmoh i forgot to mention. a blackface bassman in the uk is a rare beast. dunno if you already knew that
