ToonTrack Shoegaze drums
- budda12ax7
I love my EZ drummer, but am having a hard time finding the right drums for shoegaze...I have quite a few expansion packs and a ton of midi packs.
I'm looking for that skip beat...any ideas??? Also...it's like the Flock of Seagulls "I Ran" drum beat but slowed down...I don't want to to use loops but maybe I should for this project
see video
https://www.youtube.com/watch?v=-6gDb8JlBkQ
see video
- Plumerai
Re: ToonTrack Shoegaze drums
I used to record/sample beats from songs I like & then loop it. If you're lucky there's a bit of song with just the drums.
- Professor Bill
I was using ToonTrack for a bit and found that it's easy enough to find a beat you like well enough and then edit the midi track to taste. Drag your cursor across the track and figure out which dot is the snare. You can adjust the snare hit (or move it to another snare sound, increase or decrease the velocity, &c.) to where you like it, then you can cut and paste to repeat that bar. I found that editing the midi tracks became an engrossing task all on its own. Hours of fun, actually.
- budda12ax7
Thanks for the tip, will tryProfessor Bill wrote: ↑Sat Jun 08, 2024 6:55 amI was using ToonTrack for a bit and found that it's easy enough to find a beat you like well enough and then edit the midi track to taste. Drag your cursor across the track and figure out which dot is the snare. You can adjust the snare hit (or move it to another snare sound, increase or decrease the velocity, &c.) to where you like it, then you can cut and paste to repeat that bar. I found that editing the midi tracks became an engrossing task all on its own. Hours of fun, actually.
- Dr. Ooh
I went down the midi drum road for a while, and just ended up not being happy with it, for both writing songs and regular jamming.
The way to go is real recorded drums. Loop Loft, Yurt Rock, and Drum Drops have been my go-to’s, along with a few drum loop packs from splice, which I think are Sample Magic and Zenhiser.
Sample Magic and Drum Drops have shoegaze drum packs. Loop Loft and Yurt Rock have really great Indie drums, which work well for shoegaze. There are also some great in between packs for dream pop and I think they call it dreamgaze.
Between those options, I always have great drums to write or jam with. Sometimes I can build a full song with the loops, sometimes not. If not, I use them to get the general idea down, then hire a drummer to record the song, custom.
- budda12ax7
yea...I have a ton of loops from when I switched to a 100 percent digital recording DAW and interface, but I always felt not in control of the loops..unless I was using construction kits or stems...I guess that works too. I like in Studio One/Toon Track you can assign individual tracks for each drum.Dr. Ooh wrote: ↑Sat Jun 29, 2024 7:18 amI went down the midi drum road for a while, and just ended up not being happy with it, for both writing songs and regular jamming.
- Dr. Ooh
In that case, the DrumDrops shoegaze drums is worth checking out. They have stereo mix, stems, and multitrack versions. And there are multiple variations and multiple patterns. So there is a lot of customization capability. I tend to start out with just the stereo mixes, and if I build a full song around the drum track, when it’s time to mix, I’ll then change out to the multitrack files, to have full control of the mix.budda12ax7 wrote: ↑Sat Jun 29, 2024 9:03 amyea...I have a ton of loops from when I switched to a 100 percent digital recording DAW and interface, but I always felt not in control of the loops..unless I was using construction kits or stems...I guess that works too. I like in Studio One/Toon Track you can assign individual tracks for each drum.Dr. Ooh wrote: ↑Sat Jun 29, 2024 7:18 amI went down the midi drum road for a while, and just ended up not being happy with it, for both writing songs and regular jamming.
It is definitely less control than midi drums. And it’s definitely much easier to start out with the drums, and write around the drum parts, rather than what is most natural, writing the guitar parts and then customizing the drums to work with the guitar writing. But doing it that way a lot of times inspires me to play new things and in new ways. So it’s definitely a trade-off.
Hiring a remote session player is also worth a good thought. There are some really great drummers available, with great rooms, great gear, and great pricing. I think that’s worth looking into as well.
- budda12ax7
Thanks....really good ideas...
- jorri
might be more about the effects, like gated reverb and such. i just use alt rock, and mix it but it is intentionally towards something that it less to imitate other shoegaze drums. i layer up with a linn or other electronic drums a lot with other free plugins (more cocteau twins), but they do have a post-rock kit on EZX and to me the sound you posted is something that sounds pretty familiar to the post-rock genre (isn't it a hybrid, really?) so maybe that's up your street
- budda12ax7
I will check that out, but it's the actual beat i'm looking for. Great idea though....thank you.jorri wrote: ↑Wed Jul 17, 2024 5:19 pmmight be more about the effects, like gated reverb and such. i just use alt rock, and mix it but it is intentionally towards something that it less to imitate other shoegaze drums. i layer up with a linn or other electronic drums a lot with other free plugins (more cocteau twins), but they do have a post-rock kit on EZX and to me the sound you posted is something that sounds pretty familiar to the post-rock genre (isn't it a hybrid, really?) so maybe that's up your street
- nightgolf
this is REALLY cool dude, congrats. what midi packs/etc did you use for the drums?budda12ax7 wrote: ↑Sat Jul 27, 2024 8:07 amI will check that out, but it's the actual beat i'm looking for. Great idea though....thank you.jorri wrote: ↑Wed Jul 17, 2024 5:19 pmmight be more about the effects, like gated reverb and such. i just use alt rock, and mix it but it is intentionally towards something that it less to imitate other shoegaze drums. i layer up with a linn or other electronic drums a lot with other free plugins (more cocteau twins), but they do have a post-rock kit on EZX and to me the sound you posted is something that sounds pretty familiar to the post-rock genre (isn't it a hybrid, really?) so maybe that's up your street
- UlricvonCatalyst
At the risk of stating the obvious....do you know any drummers who can write drum notation? At the risk of generalising I think that skill is more prevalent among drummers than other rock/pop players, maybe because more of them have had tuition from beginner level.budda12ax7 wrote: ↑Sat Jul 27, 2024 8:07 amI will check that out, but it's the actual beat i'm looking for. Great idea though....thank you.
Anyway, if you know someone who could transcribe the beat in question for you it should be simple to programme into your DAW. The key would be the level of quantise you'd need (i.e. 1/16, 1/32, 1/64). As someone else said, figuring out which midi note is which drum allows you to rearrange existing patterns from EZDrummer to your own preferred groove.
Not sure what DAW you use, but in Cubase, if you go into the EZDrummer pattern, click select all, set quantise to 1/16th, and select 'fixed length' from the MIDI menu it's a lot easier to see what's going on with the drum rhythm.
- budda12ax7
The drum beat is the Flock of Seagulls "I Ran" beat.....i'm obsessed with it.
- Marc
The beat on ‘I ran’ sounds very straightforward with minimal fills.
Production sounds like a Simmons SDS drum brain that may have been triggered from an acoustic kit and the two blended together.
I’m not sure if it’s the feel of the drummer that you like that makes it have a certain something. To capture this I would use Recycle to take say a 4 bar loop and slice it where the drum beats are. Then export it as a midi file. Then import the midi file into a DAW and create a midi groove template from the file and apply it to your drums - this will impart the feel and micro timing to your beats. If there no drums only section available on say a 12” remix just use a stem splitter to extract the drums.
I don’t think this was done to a click btw.
- budda12ax7
That drum beat is on a lot of synthwave and chillwave stuff...just add the ghost snare to it. Think of the Smells Like Teen Spirit beat, but really slowed down.
