index.php?topic=6112.30
so i'm going to pull a rickenbacker style hollowbody act on it. except instead of routing a solid body from the back i'm going to route the hollow cavities from the front then cut a thin top to stick on the front of the guitar. i'm hoping that having a solid piece of thin wood on the front will transmit the vibration of the main strings to the sympathetics more effectively than if i routed from the back.
am i making any sense at all?
anyway, my questions are many...
A: what kind of wood would be the most efficient transmitter of vibration
B: where do i get a piece of wood wide enough for the front of the guitar...i'm assuming the bookmatched tops would be counter productive to my aims...+ it seems like all you can get on ebay is bookmatched pairs?
C: what kind of glue is the best for applying a top to a guitar...
D: (extra credit) what is the science of F hole placement? is my main goal to empty as much wood from the inner cavities as possible? larger resonant chambers = better transmission?
anyway, any help would be appreciated
