You might be saying, "so what's the problem, change the power supply caps in the doghouse, and the bias cap, check the tubes, change if needed, and off you go!". Well yes you are right, and here in Vienna Austria I have found a shop that sells tubes (JJ) and he also had some caps from the same company, namely a 47Mfd for the bias and 2x 80 Mfd for the power. The 3x 20Mfd, and the 16Mfd seem to be more difficult to find, and there is also a 25/25 Mfd filter cap that i will have to search for as well as a few others.
Any tips on finding good caps??
My main problem though is reading the schematic! The original fender schematics that one finds on the internet seem to be hand written and there are no high resolution scans. How do you guys read these?? I mean they are practically illegible!
So my question is; has anyone out there redrawn these schematics in a modern fashion or does anyone have a legible high resolution
scan of a Bassman AB165 circuit??
My Bassman is very similiar in date and design to Statelejazzuers post about his 68 bassman
http://www.offsetguitars.com/forums/vie ... 10&t=36784
In fact almost identical, the main difference being that mine is an export model with changeable voltage.
There are also things in there that are not on the schematic which I have read is not unusual but still makes you scratch your head.
Here are some pics, please have a look,
sorry for the bad photos..I can link to some better ones if necessary.
Cheers
Edit: the largest schematics I could find were by Kbapps but still hand scribbled.
http://www.kbapps.com/audio/schematics/ ... ab165.html
Also a very informative link about modding the ab165 circuit:
http://bwilliamson.home.mchsi.com/bassman.htm
